Riser question...
Old Jun 7, 2010 | 04:50 PM
ECSparky's Avatar
ECSparky
4th Gear
Default Riser question...
Hey yall, just bought an '06 FXDBI Street Bob. Have had Sporties, still have an 08 1200N. I've just got a question about how the risers are mounted to the upper bracket; what's with the spongyness of the mounting bolts? I realize that there must be some kinda rubber bushings in there, there appears to be a grounding jumper for the handlebars also. Is this to soften vibrations from the motor? Just feels weird when I stop, the bars pivot forward about 3/4". Do many of U remove this feature and hard mount the risers, or is this a desirable feature to most of U? Probably a dumn question, but I am curious..
Old Jun 7, 2010 | 05:12 PM
hommes's Avatar
hommes
I'd go get a wrench and put a little more torque on them bolts. 3/4 of an inch of slack seems like alot to me...unless, of course, you have the dyna with the rubber handlebars to match...
Old Jun 7, 2010 | 05:36 PM
blackmopar's Avatar
blackmopar
sounds like the stock rubber is worn out - **** mine were toast when i brought my 07 home from the dealer. the oem ones are really soft, You can get poly bushing replacements that fix the issue
Old Jun 8, 2010 | 02:45 PM
ECSparky's Avatar
ECSparky
4th Gear
Thanx! Perfect! That seems to be it. Stock rubber ones are MoCo crap. I've got a set of polyurethane bushings on the way.
Bonzai
Dec 10, 2013 08:08 PM
evanstock
Apr 25, 2011 12:04 AM
rjheff
Mar 8, 2011 02:13 PM
BradD
Sep 22, 2010 12:55 AM
russell6hp
Dec 15, 2009 09:54 PM
