I'm getting ready to change my primary for the first time on my 2010 Wide Glide. The service manual says capacity 32 oz wet or 40 oz dry, which is it? Thanks.
32 oz. even, bike must be level to get it in there. Also, I reused my rubber Oring gasket, nothing wrong with it and no leaks. Also your going to need a funnel with a small tip to fit between the case and clutch to get the lube in.
Oh, and be sure to USE a torque wrench for all the screws and the drain plugs, dang man you dont want to strip any of those case holes out or crack the case.
Yep, 32oz. Jeff W is correct about having the bike level also, barely get the quart in with it straight up/down. What do you mean you're changing the primary, putting a different cover on?
