Dyno Results
Old Aug 23, 2006 | 04:05 PM
TOMMAY's Avatar
TOMMAY
Default Dyno Results
Had my dyno tune done a coupla weeks ago but his printer was down and I just had time today and go back and get the print out.
power and torque
Old Aug 23, 2006 | 04:09 PM
TOMMAY's Avatar
TOMMAY
Default RE: Dyno Results
power and a/f ratio
Bike runs better and gas mileage is better.
Blue is fuel moto map,red is after tune.
Good Luck
Tom
Old Aug 23, 2006 | 04:32 PM
dyna2319's Avatar
dyna2319
What mods did you do to get these numbers?
Dyna2319
06 FXDWG/I with more mods than the wife knows about
Old Aug 23, 2006 | 04:38 PM
TOMMAY's Avatar
TOMMAY
Not much really. SE intake with the round nostalgic filter cover, SEII pipes,stage I down load then I added the PCIII. Bike ran good before the tune but the gas mileage fell way off after I added the PCIII. As you can see the map was really rich in the upper rpms before the tune and I tend to wring it out pretty good. Gas mileage is back up now and still plenty of power.
Good Luck
Tom
Old Aug 23, 2006 | 07:03 PM
gargamel's Avatar
gargamel
6th Gear
Hi,
Now your engine is well tune. Can you describe the difference you have between now and when you just had the stage1 without PCIII usb ?
10x
Old Aug 23, 2006 | 08:22 PM
TOMMAY's Avatar
TOMMAY
There is a noticeable difference. Before,even with the 25 degree injectors and the stage I, off idle was jerky and some surge,a little flat on full throttle accelleration. After the PCIII,smooth as silk,noticeably better acceleration in the power band but running rich,gas mileage dropped. After the tune,which leaned it up a bit,still have all the power and acceleration and better gas mileage. Well worth the 250 I spent for the tune.
Top speed before the PCII was about 105/107. Don't know what it is now,will find out when I get a chance.
Good Luck
Tom
Old Aug 23, 2006 | 08:25 PM
RonnR's Avatar
RonnR
TOMMAY Looks good,,,, PCIII and dyno next on my list...
Thanks for sharing..
Old Aug 23, 2006 | 11:36 PM
rde's Avatar
rde
Nice tune. I have a similar set up on my 06 WG and my dyno run looks very similar. I have a PCIIIusb, Arlen Ness Big Sucker, and SE II slip ons.
I have max Hp at 70.86 and Torque at 73.24 ft-lbs. AF runs at 14.
I agree, best $250 you can spend on a bike! [sm=exactly.gif]
Old Aug 23, 2006 | 11:56 PM
tb2377's Avatar
tb2377
i got a similar set up, seII slip ons, se ac, and the sert, dyno tune. 77 and 77
[IMG]local://upfiles/7785/9477752CFD5149B787589ADC769EC32D.jpg[/IMG]
Old Aug 24, 2006 | 05:51 PM
Stanger's Avatar
Stanger
Too cool!! I go in tomorrow for my Dyno run. Kinda excited to see how much better it will run. I have the PCIII, S/E Stage 1 A/C kit and Vance & Hines short shot staggereds. Runs good now, but as mentioned above, it is rich and needs to just be tuned up a bit to be completely awesome. As others have stated, best $250.00 plus I have spent (on the PCIII).
