motor upgrade
Old Jun 27, 2010 | 07:28 AM
popsfxdc's Avatar
popsfxdc
Stage I
Default motor upgrade
This past winter I installed the big bore kit on my '08 super glide custom. (SE breather, race tuner, cam, Rush mufflers) I had it dyno tuned after the break in period. It's turning just over 80 hp and just shy of 97 ft lbs at the rear. I was wondering if anyone else has had similar, or better results from the upgrade.
Old Jun 27, 2010 | 09:44 AM
redrubicon2004's Avatar
redrubicon2004
That sounds about right. What cams did you go with? What head gasket did you use? Do you know your compression ratio?
sharkey
Mar 23, 2015 09:11 AM
darkhdshadow
Oct 12, 2014 03:47 PM
stevepacman
Mar 26, 2011 06:45 PM
Josh110
Jul 3, 2009 10:28 AM
jcmer22
Mar 25, 2009 10:06 AM
