installing forward controls on 07 Super Glide?
Old Aug 27, 2006 | 01:43 PM
Whiffleboy's Avatar
Whiffleboy
Default RE: installing forward controls on 07 Super Glide?
Here is a thread explaining pretty much everything. You can use the 06 Forwards with the longer shift rod or use the 05 kit. I used the 06 kit and wedged the old shift lever behind an existing bolt. Didn't even need a cover for the old shift shaft.
All You Need To Know
Whiff
Old Aug 27, 2006 | 02:33 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
thanks
Old Aug 27, 2006 | 03:38 PM
Mascman's Avatar
Mascman
I don't really see a point in using the 2006 kit and then installing it like the older kit.
Why pay the extra money for the 2006 kit?
I got the older kit for $249 plus shipping from M&M Cycles off Ebay...no wedging required because the bracket you need is there. It also comes with the chrome cover that bolts onto the shift shaft.
I wouldn't think the 2006 kit has the shift shaft cover since you are supposed to remove it to use the kit.
Old Aug 27, 2006 | 04:00 PM
Whiffleboy's Avatar
Whiffleboy
The reason I went with the 06 Kit is because, in the event my primary needs to come off, I will have everything I need to make it perfect AND the 05 shifter linkage is a bit shorter than the 06. Planning ahead, I guess.
I got the 06 Kit for the same price you got the 05.
Whiff
Old Aug 27, 2006 | 09:54 PM
Mascman's Avatar
Mascman
I wonder why the shifter rods would be different.
My kit works perfectly and the shifter can pretty much be positioned anywhere on the shaft that you need it to be.
Is the brake rod different too?
Old Aug 27, 2006 | 11:44 PM
mikec's Avatar
mikec
You can cut the rod.........
Old Aug 28, 2006 | 12:27 AM
Whiffleboy's Avatar
Whiffleboy
ORIGINAL: Mascman
I believe the shifter rod is longer because you get a taller replacement shift lever in the 06 kit.
Whiff
Old Sep 8, 2006 | 12:30 AM
KeithB's Avatar
KeithB
I measured the shift rods:
05 is 13"
06 is 14 1/2"
looks like the 05 rod will deff work on the 06/07, i may buy a fancy shift rod anyway at some point
Ricketts
Dec 24, 2014 11:15 AM
Dyna346
Sep 3, 2013 10:12 AM
michaelvs710
Apr 8, 2011 02:46 PM
ny06fxdb
Jul 9, 2007 03:52 PM
mdog2222
Apr 10, 2007 02:00 AM
