New Combination Digital Speedometer/Analog Tachometer
Old Jul 4, 2010 | 12:31 PM
Vinsil's Avatar
Vinsil
Originally Posted by Airborne350G
Sure do.. Speedometer plug:
PIN 1: Ignition
PIN 2 DATABUS
PIN 3: Empty
PIN 4: Security LP
PIN 5: Battery
PIN 6: Accessory
PIN 7: Ground
PIN 8: Reset
PIN 9: Fuel LEvel
PIN 10: Empty
PIN 11: reset
PIN 12: empty
Ok, my 09 manual lists it as follows for a Street Bob (should be the same setup as you have) as follows.
Pin 1: Ignition
Pin 2: Serial data
Pin 4: Security LP
Pin 5: Battery 12v
Pin 6: Accessory
Pin 7: Ground
Pin 8: Trip ODO reset
Pin 9: Fuel level
Pin 11: Trip ODO reset
Pin 3, 10 are not used.
Old Jul 4, 2010 | 12:32 PM
8541hog's Avatar
8541hog
If anything is different it may be the databus connection, this is where you get your tach signal. They may have changed it dur to EPA or some such crap, hope you get the true answer, I am curious.
Old Jul 4, 2010 | 12:33 PM
Airborne350G's Avatar
Airborne350G
I know what you mean about wiring. I can do it, but I hate it with a passion.
de oppresso liber
Vinsil's Avatar
Vinsil
So.....it looks the same to me bud. Should be good to go! I think the MOCO likes to list things like that...to get you to buy that $500 one!
Old Jul 4, 2010 | 12:34 PM
8541hog's Avatar
8541hog
Looks like that is it, different type of data signal, datbus to serial data. Which means it would most likely not work.
Old Jul 4, 2010 | 12:35 PM
Airborne350G
Pin 1: Ignition
Pin 2: Serial data
Pin 4: Security LP
Pin 5: Battery 12v
Pin 6: Accessory
Pin 7: Ground
Pin 9: Fuel level
Looks the same... Do you know the part number for your ECM? Mine is 32534-05B
Vinsil's Avatar
Vinsil
Ah. I did not catch that difference. Sorry man.
Old Jul 4, 2010 | 12:36 PM
Airborne350G
Do you think if the ECM's are the same then it might work?
Vinsil's Avatar
Vinsil
I don't...where to find that in the manual? I'd be happy to look for you.
Old Jul 4, 2010 | 12:38 PM
Airborne350G
Not in the manual. HD makes you purchase a separate parts manual. If the ECM's are the same then I should be good to go. Thanks for the help.
