New Combination Digital Speedometer/Analog Tachometer
just a thought.
The main difference is the CAN BUS, this is what the vehicle information travels on, like tach, gear position, distance to empty calculations, in 2007 Nope, 08 some models, 09 most models
I installed PN 70900001A on my wife's 08 FXDF Fatbob, the tach,speedo, clock,odometers, switching from Kms to Miles all work great, 6th gear and neutral lights work fine. The only thing that doesn't work is the trip/distance to empty calc.
I am fine with that, as we wanted a tach and also to switch from Km to miles, when you order it from your dealer you have to give them the mileage and Pre pay, and it come "burned" with the correct kms or Us miles, after that it is plug and play
Cheers Ultra
I installed it the next day took all of 45 minutes and I am no Harley mechanic just a do it your self-er. No problems I followed the instructions for a change. Also there are you tube videos that I watched first.
New speedometer works great as advertized and looks good .
Sam
