Metzeler Tire Pressures
Old Aug 16, 2010 | 03:31 PM
lo-rider's Avatar
lo-rider
Default ME880's
My indy uses the 880's on her (yeah, a good-looking married lady) bike, so knew about the higher pressure. W/ almost 1,000 miles on the rear, on wet, dry & dirt roads, I was impressed enough to order another 880 for the front.
BTW I'm running the heavy-duty tubes on my laced rims, in an effort to minimize the chances of a flat. They're only an extra $10 or so. Desert racers (think Baja 1000) here run them.
Note: check your wheel bearings while the wheel is off. My rear bearings needed replacement @ 9,000 miles! Went to All ***** (American-made). This is also a good time to do a thorough wheel & inner fender cleaning and to check alignment, wiring harness, brake pads...
Old Aug 16, 2010 | 06:36 PM
docsg's Avatar
docsg
Originally Posted by schwangster
40 front
45 rear solo
48 rear 2-up
they feel better with higher pressure, for sure
That's a little higher than I run my 880's. Solo 39 front, 40 back. I got 10K out of the rear with the first set I put on (front/rear) and changed the front one with it as the Indy showed me where the sidewall on the front was cracking. It was almost 2 1/2 years old and had sat a lot on concrete garage floor without being ridden that much (about 4K a year). I know that sucks as a Harley rider but retirement is just around the corner and so is a lot of riding. BTW, I'm sold on my 880's.
Old Aug 17, 2010 | 07:21 AM
rounder's Avatar
rounder
Originally Posted by Foodog
I run mine at 32 front and 40 rear(solo and 2up). The first paragraph states to always inflate to the tire pressures stated in owners manual(30 front and 36/40 rear solo/2up). Then they contradict themselves(they stated always.. wtf) by indicating you can add pressure to get better mileage out of the tires(wear). So, as long as your running the stock Harley recommended pressure, you are not under inflated. However you can add pressure up to the guidelines on the Metzeler page shown above. So you can go up to 40 in the front and 40-42 rear (solo and 2up). You should not be running more than that in the rear as indicated on the metzeler page. You guys running more than 40 solo and 42 for 2up are over inflating the rear tire according to metzeler(Notice the second set of pressures for the me880 rear). So don't worry about the pressure if you keep it stock pressures(the tire is not under inflated). If you choose to run additional pressure that is fine too(just not too much). The added pressure will increase tire mileage(reduce wear over time). The increased pressure will cause a less comfortable ride and can cause the tire to skip over bumps more as you are reducing the stickiness of the tire(they will last longer though).
Old Aug 17, 2010 | 08:06 AM
Mascman's Avatar
Mascman
Your front is under inflated IMO.
Why would you want to go off of the HD numbers when Metzeler has recommendations listed for you?
Supposedly, the Metz has a softer sidewall...this is even more reason to go with the recommendations from Metz., and not HD, who has numbers listed for the stock Dunlop.
I just rode to work last night with 40 / 45 and liked the ride and handling so I am going to stay around those figures.
Old Aug 17, 2010 | 08:09 AM
8541hog's Avatar
8541hog
From Metzeler - "Insufficient air pressure will result in poor handling and cause a tendency for the motorcycle to "wander". In addition, improper and insufficient tire will cause accelerated tire wear, increased fuel consumption, less control and the possibilities for tire failure to due an overload/under inflated operating situation. "
Just ask Ford about recommending lower pressure than the tire manufacturer.
Old Aug 17, 2010 | 02:49 PM
Foxster's Avatar
Foxster
Metzelers are known to need higher pressure than stock Dunflops. If you pump Metzelers up to the pressure in the manual then they will be under-inflated; the bike will handle badly and could be dangerous.
Unlike some tyres, Metzelers usually list the recommended pressure on them, not the max. First ones I put on a Harley I read the numbers on the tyre wall and automatically assumed it was a max even though it doesn't say so, but reading on the Metzelers site confirms that it is the recommended pressure not max.
Old Aug 17, 2010 | 04:14 PM
plumbertom's Avatar
plumbertom
Okay that Metzeler PDf is worthless. http://www.8541hog.com/metz.pdf
In one spot it tells you one pressure and in the other spot it tells you something different.
The first page (22) it says;
Recommended Minimum ire Pressures (P.S.I.)
Touring/Cruiser
ME880 Marithon Solo 2 Up light 2 Up heavy
Front 38-40 40-42 40-42
Rear 44-46 46-48 48-50
Then in the specific model listing it says;
FXD Super Glide 06-08 (mine is an 09 but I dont think that matters) Lists the specific tire size then says; Front 38-42 Rear 40-42
Now which is supposed to be correct?
Bunch of Bullshit in my humble opinion. I just go by what's on the sidewall.
Old Aug 17, 2010 | 04:18 PM
8541hog's Avatar
8541hog
Touring/Cruiser
Seems pretty clear, why would you even look at the Touring if it gives you specifics for your bike?
Big difference between a touring bike and a Dyna.
Old Aug 17, 2010 | 04:22 PM
plumbertom's Avatar
plumbertom
If you look in the Metzler catalog they consider the Dyna Super Glide to be a cruiser, that's the way they list the tires for it.
Besides look up the specific models for the touring bikes and you'll find the same discrepancy.
az232
Sep 3, 2018 12:37 PM
sporty63
Apr 5, 2013 01:01 PM
jgcable
May 16, 2010 10:51 PM
mississippiboy
Sep 16, 2008 10:47 AM
joe v
Jan 13, 2007 11:48 AM
