I am new to HDForums and Harley Davidson all together. I have been riding around 5 years, but just bought an HD......great decision! I got a 2002 FXDWG and all was fine until a few minutes ago I went out for a ride, turned on the ignition and noticed the speedo was stuck on 40mph. Also, the turn signals don't work, no horn and my odometer is off. I checked the fuse and they are all good.... I am at a loss. I may not be posting this in the correct forum, but I looked under maintenance and nothing was there that is helpful. I thought this might be a Dyna-specific problem. Thanks, in advance for any advice.
All those connectors are right under the gas tank and accessable by removing a plastic cover/more accesible by lifting the tank a bit, front bolt only. Id check the connector first for crud n corrosion. might be an easy fix
wes for
Bet your brake light doesn't work either. Use a volt meter or test light to see if there is power at the accessory fuse with the ignition switch on
If there is power on both sides then the orange/white wire is open.
If there is power on only one side the fuse is bad
If there is no power at all then either the red/gray wire is open or the ignition switch is bad.
Thanks everyone for your help. I couldn't find anything wrong, so I bit the bullet and took it to Alamo City HD to be properly diagnosed. Hopefully things will go well. They tried to sell me a 25,000 mile full synthetic package with full fluid change and checking/adjusting all belts and chains for $455.00....seems a little steep, but like I said this is my first Harley.
