carb swap ?
Old Jul 20, 2010 | 12:29 PM
the blob's Avatar
the blob
Default carb swap ?
anyone do the conversion on an 06 dyna yet? im bored with my efi, miss the tuneing and tinkering with carbs and not to mention the better engine sounds.
thinking of letting the dealer do it, or do you think its not a big deal to do your self?
Old Jul 20, 2010 | 03:19 PM
ghostrider69's Avatar
ghostrider69
I will be doing it on my 09 but it is on the back burner right now. It appears to be something that is pretty simple and straight forward. The best and most cost effective way I have come up with is to use the Thunderheart stand alone ignition, S&S Super E carb kit for a twin cam, bung adapter for the tank, petcock, throttle cables. For the thunderheart to work all it needs is the crank position sensor, positive, negative and tie into the coil.
Old Jul 20, 2010 | 03:31 PM
ackman1968's Avatar
ackman1968
I would bet the dealer wouldn't even consider doing it. You would probably have to go to an indy if you didn't do it yourself.
Old Jul 20, 2010 | 03:34 PM
ackman1968's Avatar
ackman1968
Here's some reading for you. https://www.hdforums.com/forum/dyna-...ider-this.html
the blob's Avatar
the blob
thanks for the info ghost rider! ill lookinto the carb kit and ign.from thunder heart.
i got a qutoe from the dealer for 3000 dollars!!
theres a vid. o you tube that shows an 07-08 flhr that had the conversion done and it sounds awsome!!!
thanks man.
Old Jul 20, 2010 | 03:38 PM
ghostrider69
If you do the conversion yourself you should be able to do it for less than $800.00.
Old Jul 20, 2010 | 05:18 PM
SURFOR Chop's Avatar
SURFOR Chop
thanks man.
Woah ... was kind of surprised to hear a dealership would countenance such a thing to begin with ....
Did they warn you it would void the warranty ...?
R/
'Chop
Old Jul 20, 2010 | 10:08 PM
the blob's Avatar
the blob
my bike has no more warr. but corp. harley said they didnt recomend it, but it could be done
guy at the counter said with all parts and labor its 3000!!!!!!!! and they done a bunch since 07!!
i just dont have that kind of money right now.
Old Jul 20, 2010 | 10:12 PM
the blob's Avatar
the blob
just got an e-mail from chris at daytona twin-tech and he said they have a module just for this purpose. its only 200.00! he sent me a pdf.file on the box and it looks pretty simple plug and play kind of.tcfi III. so im pretty sure ill go this route, after more studying.
in the e-mail he also said he can assemble a kit for me with carb i think!
Old Jul 22, 2010 | 04:11 PM
SURFOR Chop
If you post your TTS tuner for sale, I think there are a few guys who would probably jump on it ... (post over in the classified ads section of the forum and mention it on your thread here) ....
Would help free up some cash for your carb conversion project ....
Just an idea ....
R/
'Chop
