Left turn blinker button not as responsive
Old Jul 20, 2010 | 09:42 PM
elizer's Avatar
elizer
Default Left turn blinker button not as responsive
My left turn button is not as responsive as the right turn one. the right turn activates and deactivates instantly on each press. The left turn however sometimes require multiple presses to activate and deactivate. Ii have the panacea taillight and the rear run-turn-brake controller if that helps. Not too sure what it could be? has anyone had this problem and possibly have a solution for it
Old Jul 20, 2010 | 10:30 PM
bberck's Avatar
bberck
Take the housing apart and make sure the switch is clipped in all the way. They will some times pop out on one side and cause it to do that.
Old Jul 20, 2010 | 10:48 PM
elizer's Avatar
elizer
ok awesome ya ill definitely check that out thanks!
Old Jul 21, 2010 | 07:46 AM
bberck's Avatar
bberck
One side slides under a lip and the other just pops into the case. If it's not in just push it in with a screwdriver and that should fix it.
kmealp
Apr 23, 2012 10:10 AM
zeus33
Sep 28, 2009 10:07 PM
Dynamike06
Jul 13, 2009 08:42 PM
Dr.Cool
May 10, 2007 11:13 PM
cartman18
Jul 18, 2006 02:14 AM
