Harley brake fluid reservoir filler caps stink...
Old Jul 31, 2010 | 03:36 PM
jimbobob's Avatar
jimbobob
Default Harley brake fluid reservoir filler caps stink...
Any tricks on how to keep the fluid in the reservoir and not on it. I replaced the front lid twice and need to replace the rear but have not. I refuse to use a chrome cap ...but don't like the black paint stripper bubble look either.
It seems once they leak they are finished...I clean and tighten still leak over time?
Old Jul 31, 2010 | 03:42 PM
SBRob's Avatar
SBRob
Seems like the most common cause for leaking is folks over tighten it...
Old Jul 31, 2010 | 03:43 PM
kk6pg's Avatar
kk6pg
How tight are you cranking them down?
just run the screws down so the gasket barely starts to distort. Anything more will leak.
Old Jul 31, 2010 | 03:53 PM
jimbobob's Avatar
jimbobob
[QUOTE=SBRob;7079508]Seems like the most common cause for leaking is folks over tighten it...[/QUOTE
I understand, but once it leaks, I clean retighten, not too much, still leaks. I understand about over tightening, but when it keeps on leaking, its almost counter intuitive to not give a quarter turn more.
Old Jul 31, 2010 | 03:55 PM
kk6pg's Avatar
kk6pg
Just watch the gasket when you run the screws down. The moment it starts to bulge, STOP
Old Jul 31, 2010 | 04:03 PM
jimbobob's Avatar
jimbobob
Will try...Thanks
Old Jul 31, 2010 | 04:16 PM
DCLXVI's Avatar
DCLXVI
My theory is that this has been a problem for quite a while but when Harley switched to DOT4 we started seeing the paint problems. I guess they will have a fix eventually. Mine slowed down by not tightening it as much but just enough gets out to damage the paint. I spray painted it several time and finally just gave up and now I run bare aluminum and just polish it every once in a while.
Old Jul 31, 2010 | 04:36 PM
jimbobob's Avatar
jimbobob
The paint on the cover is annoying...the paint on the tank is what really worries me!
Old Jul 31, 2010 | 05:16 PM
ghostrider69's Avatar
ghostrider69
Mine used to do the same thing. When I switched all of my stuff over to chrome which is all Custom Chrome parts I have not had one single leak. Just goes to show ya that sometimes the cheaper parts are better.
Old Jul 31, 2010 | 05:21 PM
jimbobob's Avatar
jimbobob
Do they make there caps in black?
