Steering stem and triple trees
Old Jan 25, 2011 | 11:38 PM
04custom's Avatar
04custom
Stage I
will a 99 fatboy frontend fit on a 04 fxdwg?
Old Jan 26, 2011 | 02:13 AM
952dave's Avatar
952dave
I think that the 49mm forks would look good, but something to keep in mind is that they are still relatively new, so there isn't an abundance of those type of parts flooding the used market. If you decide to go with the 41mm you'll be able to find significantly more parts for alot cheaper. I know that you cant gain as much performance, but do you think theres a significant difference for the average rider?
Old Jan 26, 2011 | 08:21 AM
SURFOR Chop's Avatar
SURFOR Chop
Should work as far as dimension of the parts, etc. ...
That said, modification will have to be done (i) to the fatboy lower triple tree (widening the turn stops for the FXDWG frame) ... and (ii) clearance the FXDWG fork stop (can be done by either cutting it down or clearancing the FLSTF headlight mounting casting on the lower triple tree) ... the usual stuff to get a Softail front end on a Dyna frame ....
R/
'Chop
Old Dec 23, 2012 | 06:53 PM
Shvlhdtk27's Avatar
Shvlhdtk27
Stage I
Default 96 low rider versus wide glide
I'm wanting to know what's the difference between the steering neck on the frame between the 96 low rider and wide glide what all do I have to change to put a wide glide front end on a lowrider frame
Kevin714
May 25, 2013 04:12 AM
kurt84
Jul 13, 2009 09:21 AM
werewolph
EVO
Feb 1, 2009 12:28 PM
johnwwwatson
Oct 13, 2008 03:11 AM
spot1970
Aug 10, 2008 02:53 AM
