Power Commander, XIED or stock?
Old Aug 3, 2010 | 07:31 PM
DVassino's Avatar
DVassino
Default Power Commander, XIED or stock?
Hello,
I have a 2007 Low Rider with SE street legal mufflers, SE air cleaner and the ECM download. The bike normally runs great but the heat from the engine is pretty bad and I get surges on deceleration that vibrates through the handle bars. I have read in some of these threads the a fuel manager will help both problems. Does anyone have a recommendation and also where the hell would you put the Power Commander? There is really no room under the seat.
Thanks,
Dino
Old Aug 3, 2010 | 07:34 PM
lencap's Avatar
lencap
I had similar issues on my Heritage. I posted a detailed write-up about the XiED in the Softail section. You should be able to find it with a quick search.
For me the XiED was the best solution. Worth a look.
Old Aug 3, 2010 | 07:50 PM
TopKat's Avatar
TopKat
What was the title on your post and how long ago? I'd like to read it too.
Old Aug 3, 2010 | 08:05 PM
jim425's Avatar
jim425
IED or XIED would be the best choice for me. I got the IEDs and in tests I've read the engine does run cooler.
Old Aug 3, 2010 | 08:10 PM
plumbertom's Avatar
plumbertom
Oops, must have stuttered
Old Aug 3, 2010 | 08:11 PM
plumbertom's Avatar
plumbertom
Absolutely give the Xieds a shot. They will do nothing but slightly enrich your AFR and that should provide a cooler running engine. it did for my '09 FXD with SE A/C and Muffler upgrades. The down load keeps that 14,7 AFR to meet the federally mandated emission standard.
$100 for the Xieds are a good investment. You may ask around and find someone who had them and later switched to a PC or other fuel control system and will sell them to you cheap.
There is very little that can go wrong with them and they don't wear out .
Old Aug 3, 2010 | 08:19 PM
Mebeebo's Avatar
Mebeebo
You can say that again.............oh, you did.
Brian McKenna
Jun 10, 2010 10:38 PM
mcman
May 4, 2010 07:38 PM
SoftailDon
Mar 12, 2010 04:16 PM
easy4me
Aug 7, 2008 12:15 PM
RK07
Aug 29, 2007 05:39 PM
