Baffles - ruining the motor
Old Aug 12, 2010 | 09:39 AM
PoCoBob's Avatar
PoCoBob
Anyone who says back pressure is a myth has never tried driving a car with open headers down to the muffler shop. They don't run worth a crap. You have to rev the sh*t out of it to keep it running. Once the mufflers are on it's goes back to running right. Back pressure must be doing something.
Old Aug 12, 2010 | 09:55 AM
atlantaallen's Avatar
atlantaallen
Hogwash to ruining your engine fast or slow if you run without baffles as long as you jet/remap properly. Saying you will is misleading and is only part of the story.
Losing some low end is true, but you will also pick a little hp on the top end.
I've don't think racing bikes, cars, or boats run anything other than straight tuned pipes with no baffles. Maybe some superbikes do, don't know. Think about itthough.
For the record, I don't run straight pipes.
Old Aug 12, 2010 | 10:12 AM
Badmonkey's Avatar
Badmonkey
Read Post #7
Grendal Your Dead On
Old Aug 12, 2010 | 10:20 AM
Grendel4's Avatar
Grendel4
Well..... It's really not back pressure. But that's a usable term for us novices. It would, however, drive engineers to suicidal thoughts.
If you watch drag races, or almost any other kinds of professional racing, those cars run little to no pipes. If you look at the Harley/V&H NHRA Pro Stock Champion bike, you'll see dual pipes about a foot long. That bike idles like crap too. And you have to rev it to keep it running, too.
If your example car could turn 10,000 RPM, it would run fine with no exhaust system and just headers at ten grand. But don't try that, you won't like what happens.
We don't live in that world. We don't leave stop lights at 5,000 RPM and power shift at 9,500 RPM. We also don't chug along like a Mack Diesel turning 1,500 RPM most of the day. So we have to find and use exhaust systems that work in a variety of situations.
For us, there is no such thing as a perfect solution. It just doesn't exist. Drag pipes work fine at lower RPM but they're done at 4,000 RPM. Done. Restrictive systems work fine at about the same RPM range. More open 2 into 2 systems lose some torque at lower RPM but seriously come to life in the higher ranges. 2 into 1 systems are probably the best compromise of all of them but even THEY aren't perfect.
There's no such thing as perfect for us. Only personal prefences.
Old Aug 12, 2010 | 10:33 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The exhaust pulse also helps scavenge the exhaust from the exhuast port/valve area. My question what is the word "ruin" meaning? Is it going to pysically damage (ruin) the engine. Or the performance of the engine will be degraded (performanced ruin), yea sounds goofy. But go back to your source and ask in what aspect does he mean ruin.
Old Aug 12, 2010 | 12:19 PM
MDER123's Avatar
MDER123
He talked about damaging the heads? He also says every Harley needs an "upper end" at about 30,000???????????
Old Aug 12, 2010 | 01:57 PM
nevil's Avatar
nevil
Originally Posted by Punchsmack
Dude, hopefully it's ok I call you dude, check out this thread on our site:
https://www.hdforums.com/forum/dyna-...ffler-mod.html
Removing the stock/SE baffles and replace with Cycle Shack baffles. Not sure what your muffs look like on your '04, but they'd probably fit. A lot of other people did the same mod with great success. Louder and still the whole "back pressure" thing.
I'm doing this in the coming weeks.
My Cycle Shack slip ons will be here tomorrow. The tuner who is working with me said they are almost identical to the old SE mufflers and make it easier to tune the bike than the V&H I have now. We will see, but for under $200 it's worth a try.
Kazziam
Aug 25, 2009 03:03 AM
Dallastx
Jul 6, 2009 09:18 PM
jfm5
Jan 13, 2009 01:26 PM
Clinton350
Oct 19, 2008 07:41 PM
Subvamp
May 22, 2008 06:52 PM
