Left Rear Run Light Not Working
Old Aug 22, 2010 | 10:39 PM
bcmiles's Avatar
bcmiles
Default Left Rear Run Light Not Working
I realized tonight that my left run light was not working. Brake and Turn still work fine. Checked the wiring at the harness and under the fender. Wiggled the wiring around everywhere, basically checking everything except for the wiring in the actual turn signal housing. Fuses also look fine.
Anyone have any guesses? I bought this Bob from the dealer two months ago, I'm assuming the warranty will cover this if I can't figure it out?
Old Aug 22, 2010 | 10:55 PM
kenfm2000's Avatar
kenfm2000
I know this may seem too simple but brake and blinker use the brighter element in the bulb. The running light uses the dimmer element. Have you replaced the bulb?
Old Aug 22, 2010 | 10:58 PM
bcmiles's Avatar
bcmiles
I was under the impression that the bulb couldn't be replaced without changing the entire turn signal assembly?
On the way home it would work after I hit bump, then go back out. I assumed it was a loose wire somewhere, but can't find anything.
Old Aug 22, 2010 | 11:13 PM
kenfm2000's Avatar
kenfm2000
There is a small slot on the lens where you can use a screwdriver or a penny to pry the lens off. Typically the slot is usually positioned at the bottom of the lens on a new bike. Inside you will have an 1154 bulb you can replace.
Old Aug 23, 2010 | 12:55 AM
Stomper-63's Avatar
Stomper-63
You definately have a loose electrical connection somewhere if what you said is true... going over a bump and it comes on for a moment, then goes back out. It could be something as strange as the element in the bulb being loose on the inside where you can't see it.. I've seen stranger things happen.
Old Aug 23, 2010 | 07:15 AM
bcmiles's Avatar
bcmiles
Thanks guys. I will get a new bulb this evening and try it out.
Old Aug 23, 2010 | 07:25 AM
sniper77's Avatar
sniper77
You better check that bulb before you buy one, it may be a single filament bulb.
If you are running a stop, turn, brake module you probably have an 1156 single filament bulb and if the running light isn't working the module has failed.
Old Aug 23, 2010 | 07:34 AM
kenfm2000's Avatar
kenfm2000
I got the number wrong, I use a 1157 in my 09 Street Bob. It's still a dual element bulb though.
broncobob
Jul 5, 2013 11:10 AM
Cabose
Jul 24, 2012 01:11 AM
red deuce
May 8, 2012 04:24 PM
Gary86
Jun 21, 2011 05:03 AM
stoneman
Jun 24, 2007 04:32 PM
