Filter Element changeout... any consequences?
Old Aug 25, 2010 | 09:47 AM
Stomper-63's Avatar
Stomper-63
Default Filter Element changeout... any consequences?
Hey all,
I'm a HD newb who bought an '06 SB in January (I'm the 3rd owner as far as I can tell), and its fast approaching the 10,000 service interval. It has SE-2 Slip-on's, and a SE Stage-1 A/C setup. The filter element is P/N 29442-99C... I can see it's not the highest quality and want to replace it with a K&N HD-800. In your opinions, will this upgrade affect any mapping that may have been done to the bike or are the two "close enough" in air flow characteristics to not worry about it?
Also, there was just a small dribble of oil inside at the bottom of the throttle body that looks like it came from a port at the top that has a line that runs somewhere to the motor (I assume its from the crankcase.. haven't looked to hard yet), is that normal to have that happen?
The bike runs like a raped-ape and cranks out PLENTY of power with a combined GVW of vehicle/passenger(s)/equipment of over 1000-lbs.
Thanks for any input!
Old Aug 25, 2010 | 10:10 AM
nkauf21's Avatar
nkauf21
I switched to the K&N filter and it didn't affect anything.
JRK5892's Avatar
JRK5892
nope you can pop in a new filter without a problem bud... i am not sure what you are refering to on the oil drip? have a picture and i would be more than happy to help in any way i can...nice bike... same one i got...
Old Aug 25, 2010 | 07:47 PM
Stomper-63's Avatar
Stomper-63
Thanks for the replys, guys!
Joe, after looking just a few minutes ago with a "fresh mind", that port (at the 12 o'clock position) is connected to a sensor, not a hose.... DOH! I wiped the grime out of it last night, but I rubbed an oily finger around to simulate where I saw the oil (at the 6 o'clock position). Notice the oily gunk still on the edges of the butterfly valve (for a lack of a better term) in the top photo, then in the bottom photo with the throttle opened you can see the build-up along the axis of the valve.
I'm thinking its from the breather hoses you see on either side of the intake... from what I've been reading in the service manual, the oil is supposed to be seperated from the pressurized air/vapors when taken from the crank case before it gets to the A/C assembly....
Joe, for what its worth (coming from me), I have grown to respect your motorhead skills since I've been lurking here starting back in January, and I appreciate any input you may have on this! BTW- Your bike (and it's specs) are the SHIZZO!
cheers,
-Tony
Old Aug 25, 2010 | 09:29 PM
SC-Longhair's Avatar
SC-Longhair
The residue you'e finding is infact oil blow-by coming from the breather filters inside your rocker box (top of the motor).
Old Aug 25, 2010 | 09:40 PM
SURFOR Chop's Avatar
SURFOR Chop
The "port" at the 12-O-clock position in the throttle body is the Idle Air Controller (IAC) ... when your bike is at idle, the butterfly is closed and the air that allows the motor to idle is being inducted through that hole ... if you want to do a brief experiment, start your motor without the air cleaner in place (i.e., as you show in your photos) ... the butterfly will be closed, but the motor will still be idling ... if you put your finger over the hole, your motor should die ... it is being starved of oxygen with which to sustain combustion ....
That is also a (one of the) test(s) for an intake leak ... if you had an intake leak, the motor would not die ... it might slow down significantly, but if it doesn't die that indicates you have an intake leak ....
The ECM (electronic control module) carefully modulates the IAC to ensure your bike starts and idles correctly ....
R/
'Chop
p.s. you might consider shooting a brief blast of carb cleaner up into the IAC ... to ensure you didn't introduce any foreign matter into the IAC that might block the passage ....
Old Aug 25, 2010 | 10:57 PM
Stomper-63's Avatar
Stomper-63
Excellent insights, guys... thanks! So my thinking was correct (after reading the service manual) about the source of the oil, should I be concerned about it? It wasn't like there was a half-pint puddled up in there...
Old Aug 26, 2010 | 09:54 AM
JRK5892's Avatar
JRK5892
no nothign tyo worry about just a bit of blow by, if you run catches off it that will take care of it or take just a touch of fluids out... tat shows that you ride your bike!
Old Aug 27, 2010 | 06:36 PM
mud's Avatar
mud
....yessir... normal... result of crankcase ventilation
only reason to be concerned would be
if you would like the four sensors that are inside your induction module
.....to remain uncontaminated......
myownself, I do not want that muck coating.
pix below are of my Crankcase Pressure Evacuation System with collection reservoir...............
CLICK any picture for fullsize image
....some browsers you have to click again when it opens....
picture below is the puddle above after it settled out for awhile............
azgrumbles
Jun 22, 2017 11:58 PM
BaldHOG1222
Sep 1, 2012 10:50 AM
AndyinTally
Oil Archive (no new posts)
Mar 27, 2012 11:47 AM
KeiSki
Jun 4, 2011 08:10 PM
RichMik
Mar 23, 2006 09:59 AM
