Muffler Mod...
Old Aug 26, 2010 | 08:10 AM
hdgzr's Avatar
hdgzr
Thumbs up Muffler Mod...
So...did the Cycle Shack baffle swap on my '09 Bob. I was going to use stainless steel scouring pads to hold in the packing, but there just wasn't enough room in between the new baffles and the packing, so I just pulled out the stockers and replaced with the 'Shacks.
I used the 1 3/4" exhaust pipe spacer, cut it off flush with the inlet end of the baffle, then seated it with a rubber mallet in the muffler can. Something odd, in that the baffle went into the bottom (front) muffler about 3/4 inch or so farther than the other. The back muffler I was able to secure the baffle using the existing rivet holes. Unfortunately, I had to drill a hole in the front muffler...about a half-inch farther in enough to catch the outside edge of the baffle. I only used one bolt on the front, and it's on the bottom and pretty much outta' sight. It'll work until Santa brings the new pipes.
Sound is good, not obnoxiously loud. Just a nice mellow rumble to alert tha cage drivers next to me in traffic...which was my main concern (and that feeling of comfort for mama when she hears me comin' down the road).
Not a bad job to undertake...took about three hours by the time I cleaned up my mess and took her out for a test run (I'd say a two beer job)...right about bedtime for the neighborhood!
Got a little carbon staining on the underneath of my back muffler...never noticed that before. Don't know what that ****'s about...
Old Aug 26, 2010 | 09:30 AM
dpriest's Avatar
dpriest
what? no pics??
Old Aug 26, 2010 | 11:15 AM
hdgzr's Avatar
hdgzr
Thumbs up Here's the pics...
The first one is obvious. The second is the fitment of the CS baffle in the rear muffler can. The third is the fitment in the front muffler can. The last picture is of the carbon staining on the belly of the rear can.
Sorry, no sound clip capability.
Attached Thumbnails Muffler Mod...-picture-002.jpg   Muffler Mod...-picture-003.jpg   Muffler Mod...-picture-004.jpg   Muffler Mod...-picture-005.jpg
Old Aug 26, 2010 | 11:55 AM
Punchsmack's Avatar
Punchsmack
The "1 3/4" exhaust pipe spacer". Can you explain a bit more. I was hoping to get this same project done this weekend with my dad but I don't really get what I need. Maybe it's because I haven't seen the inside of the muffs yet and don't get the part needed. Any pictures (probably too late with it already being IN THE BIKE)?
Old Aug 26, 2010 | 12:16 PM
hdgzr's Avatar
hdgzr
It's a straight piece of 1 3/4" OD exhaust pipe stock, that is 1 5/8" ID. Got it from Advance Auto Parts.
Old Aug 26, 2010 | 06:31 PM
gonzo956's Avatar
gonzo956
got a part # on those cycle shack baffles or the BCT baffles by any chance?
Old Aug 26, 2010 | 09:13 PM
Punchsmack's Avatar
Punchsmack
Tons of info here: https://www.hdforums.com/forum/dyna-...ffler-mod.html
Cycle Shack replacement baffles. The Drag Specialties part number is 1861-0468. Price is $38.95.
Old Aug 27, 2010 | 07:46 AM
Gary7's Avatar
Gary7
Just because the cycle shack baffle will seat deeper than the rivet holes in the muffler can doesn't mean you have to seat it that deep. It's a little longer than the stock baffle so as long as you seat it as deep as stock you can be sure it's over the internal head pipe inside the muffler. You should have lined it up with the holes in the can, drilled, and secured it with screws.
SavageChopper
Jan 20, 2014 11:27 AM
Karsten
Dec 25, 2010 12:31 AM
brenn
Dec 11, 2010 10:39 AM
locodude
Aug 30, 2010 08:19 AM
apachethunder03
Exhaust System Topics
May 11, 2007 01:53 PM
