Another pipe baffle question
Old Dec 11, 2010 | 06:53 AM
brenn's Avatar
brenn
Default Another pipe baffle question
I know there is probably an exhaust forum here somewhere, but it doesn't look like there is much traffic on the specialty DIY forums, so I wanted to ask more people.
I got some baffles to try in my Samson pipes. This style:
The big end is a little loose inside the pipe - not 1/4 inch or anything, but loose enough that it isn't touching all the way around. Is it supposed to be loose? Does it matter? Any installation advice?
Old Dec 11, 2010 | 07:31 AM
handyhoward's Avatar
handyhoward
Before you put the baffle in wrap it with this Silica Fabric from www.mcmaster.com/#8799k3/=a3m8sr It not only takes the rattle out of the baffle, it tunes it to a deep throaty sound. About $10 delivered
Old Dec 11, 2010 | 07:43 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Or use a nut and.or washers in between the pipe and the exhaust so it sets tight. If it is loose it will rattle...If it is held in tight it will be fine.
Drew
Old Dec 11, 2010 | 09:32 AM
hspring03's Avatar
hspring03
That's the same one I used in my fishtails..... I was able to just tighten it up using the nut.. It didn't need to be touching all around.
Nice thing about those is that you can play with them. I started out with the whole baffle. Too quiet. I cut it in half... Better, but still not there. So I took a 1/2" rod and banged it down through so that the fins opened up a bit... Still provided plenty of baffle and back pressure, but gave a great sound.... a little rasp, but not obnoxious.
Old Dec 11, 2010 | 10:39 AM
brenn's Avatar
brenn
Thanks to everybody for the responses.
I'll probably wrap the baffles. I was thinking I could keep them in for going to work, but occasionally pop them out for going to a motorcycle event.
JimmieJack
Exhaust System Topics
Sep 10, 2012 10:33 PM
troop
May 15, 2012 10:32 AM
locodude
Aug 30, 2010 08:19 AM
MYKSHD
Jul 29, 2010 12:05 AM
apachethunder03
May 11, 2007 01:53 PM
