Autolite Sparkplugs SUCK!!!
Old Sep 7, 2006 | 12:41 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default Autolite Sparkplugs SUCK!!!
Well I put a set of autolites in the LowRider to see if there was any better performance and the screw on cap on the one in the rear cylinder keeps vibrating loose and shorting out and throwing the "no combustion in rear cyl" diagnostic code. Those little threaded screw on caps are a breakdown waiting to happen.......back to the HD plugs tomorrow.....[:@]
Rant off..........[sm=rant.gif]
Old Sep 7, 2006 | 12:50 AM
SDMF's Avatar
SDMF
Default RE: Autolite Sparkplugs SUCK!!!
You might want to try a small dab of blue loctite on the threads. Not much, but it may fix the problem if the plugs are good otherwise. Just a thought.
[IMG]local://upfiles/9114/0C079292B7834A00B7F5AD3E6EA585C3.jpg[/IMG]
Old Sep 7, 2006 | 12:59 AM
springer_'s Avatar
springer_
No lock tight needed. With a pair of vise grips, set it to lightly crush the aluminum screw on tip. Then check to see if it screws on with a little resistance. If not, give the vise grip adjustment screw a 1/4 turn and crimp it again. You only need to crimp top part of the aluminum tip so the last few threads grab.
FWIW, I only use autolite plugs in my shovel. I find they are the only ones that hold up.
Old Sep 7, 2006 | 01:02 AM
KBFXDLI's Avatar
KBFXDLI
I tried the vice grips and the damn thing still vibrated loose........I think the plug probably gets too hot for the blue loctite. I wonder if the red loctite hold it on there?
Old Sep 7, 2006 | 01:03 AM
Shovelhead Bob's Avatar
Shovelhead Bob
How many times have I said it........
ION Sense does NOT WORK with other plugs!!!!!!!!
You got the bike, you use good quality oil, and it's BLACK.... These are all positive things........
The negatives..... Hmmmmmmmmmmmm.... Cleve Brownies (Little Girl Scouts), Autolite plugs, and NEVER use LOCTITE on a plug on a bike with an ECM......
Go Stillerz!!!!!!!!!!!!!!!!
Old Sep 7, 2006 | 01:07 AM
KBFXDLI's Avatar
KBFXDLI
Ok, fine........I saved the HD plugs and when it cools off I'll put em back in.........
[IMG]local://upfiles/8030/219714A8B1174643AE69952E31EB2FCC.jpg[/IMG]
Old Sep 7, 2006 | 01:33 AM
voyager1's Avatar
voyager1
messing with different plug brands will cause many issues,my opinion,stay with hd plugs.
Old Sep 7, 2006 | 02:03 AM
springer_'s Avatar
springer_
Ion sense is not new. It is also not specific to Harley Davidson's. Ion sense absolutely works with non HD plugs. If it is a direct cross, it will work with ion sensing.
Ion sensing occurs at the time of ignition. During the combustion process a voltage is applied across the plug. At the time of combustion, ions are created and current flows. The amount it flows can then be used to determine several things including knock and misfires. Knock produces a pulse wave in the cylinder and that wave can be detected in the ion current flow. Misfires have no combustion process and therefor produce no ions to sense, which in of itself is seen as a misfire.
Ion sensing works with standard spark plugs. Spark plug wires can effect the sensing. Keeping up on the plug wire condition is more important in an ion sensing system.
Some plugs can through erroneous codes, typically associated with resister plugs in place where resister plugs were not stock. Also platinum plugs can effect sensing but theoretically should not. Harley sells SE platinum and gold plugs as well as stock plugs that were not specially made for Ion sensing ignition.
Old Sep 9, 2006 | 11:35 PM
jimw411's Avatar
jimw411
IRun the Autolite fine wires, gapped at .40 and they work great. I trusted Autolite platinums since thats what i've been running in my Ford Ranger for 65,000 miles (on my second set) and they are great....
Old Sep 10, 2006 | 04:22 PM
voyager1's Avatar
voyager1
they fine in cars,i just do not like them in bikes .
Highway Guy
Sep 19, 2013 08:57 PM
rockon
Jul 5, 2013 02:52 PM
apehanger65
Mar 25, 2013 06:05 PM
Florida Swamp Yankee
Oct 8, 2012 01:36 AM
Jackstraw
Aug 3, 2011 10:04 AM
