Friggin torx bits!!
Old Aug 28, 2010 | 04:04 PM
lstcause616's Avatar
lstcause616
all i use is snap on or mac tool but theyre prices stuff. i need it seeing that i work on exotic cars for a living.
Old Aug 28, 2010 | 04:21 PM
sniper77's Avatar
sniper77
The only Torx bits I have ever broken were T45 trying to break brake rotors loose. I've broken Snap-On, Cornwell, Craftsman and, Harbor Freight T45s using everything from a 3/8" ratchet to a 3/8" breaker bar to a 1'2" drive breaker bar....conclusion: Those freakin' bolts are TIGHT!
I can also say out of all the brands mentioned above I have never bought a set of Torx bits that did NOT include a T27.
Derby covers, inspection covers and brake and clutch lever brackets are all T27. Primary drain plugs that use Torx are T40. Switch covers are T25.
Like most here, I have never seen a Torx+ on any Harley application.
Old Aug 28, 2010 | 04:43 PM
Sharknose's Avatar
Sharknose
Originally Posted by Taddeoeg
Many HD bolts are actually Torx Plus, which is shaped slightly different and runs a bit oversized. So a "T27" might in fact be a T25P.
Torx will go into a TP and appear to fit but be loose enough to cause stripping. TP won't go into a torx, so its easy to tell which you have. I always try my TP first and only if it won't fit do I go for the Torx. But on my 07 and 09 nearly everything is TP. On the 2000 it seems some are Torx and some TP, but the latter could have been changed by a PO. I don't know when HD switched (but I do know they call everything "Torx" in their service manuals).
Oh, and the derby is actually T25P (torx plus). A T25 wobbles like a 90 year old man, a T27 still has play, but a T25P fits perfectly.
Sears sells a nice set of SK Torx Plus which include a T27P and they're having a sale today if you order online.
http://www.sears.com/shc/s/p_10153_1...5&blockType=G5
Wow--$100 for a set of bits. I'd have to use them a LOT more to make writing that check worthwhile.
Old Aug 28, 2010 | 05:31 PM
Jaymac3772's Avatar
Jaymac3772
Get Craftsman bits.
Old Aug 28, 2010 | 06:30 PM
mud's Avatar
mud
Originally Posted by scottyd
Can anyone suggest some decent torx bits that wont break or strip in the bolts?
there is no other choice - SnapOn Heavy Duty -
209EFTXBY
sometimes you wanna give em a good whack.........
Old Aug 28, 2010 | 06:37 PM
Retrop's Avatar
Retrop
Harley uses Torx Plus. Common mistake, lots of guys have trouble with using wrong size on derby cover.
Old Aug 28, 2010 | 07:10 PM
iamrfixit's Avatar
iamrfixit
Default Harley does not use Torx Plus
HARLEY DOES NOT USE TORX PLUS!
There was a long thread about that earlier this year and a whole bunch of people went out and bought torx plus sets only to find they did not fit much of anything on the bike. I can't find the actual thread but here is a thread in response to it.
The biggest mistake being made is using a T25 when you need a T27. Get a good quality set, I bought a whole set of Snap On Torx, metric hex and standard hex in a blow molded case on ebay for $150 that were just like new, money well spent. An impact driver you strike with a hammer like the one in Mud's post is also a great tool for Torx, hex or even phillips or straight machine screws.
Old Aug 28, 2010 | 07:19 PM
sniper77's Avatar
sniper77
Originally Posted by iamrfixit
HARLEY DOES NOT NOT USE TORX PLUS!
I'm sorry, I'm not sure everyone heard you. Would you mind to repeat that?
Old Aug 28, 2010 | 07:28 PM
pcbunn's Avatar
pcbunn
Derby cover is a standard Torx 27. Best quality are Wiha (German), Snap-On and Armstrong imho.There are no Torx-plus on a Harley.
Old Aug 28, 2010 | 07:29 PM
iamrfixit's Avatar
iamrfixit
Seems a lot of folks don't actually read the posts just skim over, we don't really need a repeat of the last go around with torx plus.
