My first Harley,,,couple of questions
As of now I have 23K on the Harley and everything runs just fine, only add on's are a KN air filter and Vance Hines pipes and a stage 1 jet kit to richen up the lean air/fuel from the filter and pipes, 48 slow jet and a 195 main jet.
The belt drive concern's me, and the useful life I have with it. What kind of service life can I expect out of this belt ? I dont want to get stranded out in who know's where with a broken belt. Replacing the belt is not like a chain on my old 650 LOL,,,,with this Dyna, it is a different deal to replace and could be a winter project item. Do I replace it this winter or do I have miles left in it??
My other issue is the cam bearings and the problem they seem to bring on,,,what, when, or where do I do anything with this as well. How will I know I have a cam bearing problem,,,when or if it occurs.
When I bought this new bike my ideal was to get a long life engine with little problems,,, What kind of useful miles can I expect from the engine,,,my old Yamaha seemed to need new rings about every 20K miles and a valve job,,,I think this engine can do better,,,for sure.
Thanks
Thank you for the advice,,,,and I can agree about the belt and its age as a factor,,,I think I have a concern because of deterioration vs the miles.
I imagine I will be good for the rest of the summer ,,,,I don't ride hard at all and put little of any stress on the belt.
I guess that gives me 2 winter project's,,,,final drive belt replacement and a engine build on my Vette,,,,who cares if the winter will be as bad as last years
I will be tucked away in the shop.Thanks
I was looking at my service manual tonight and replacing the cam bearings and chain tensioner's should be no big deal to do. In fact I can take the cam plate cover off and ck out the primary tensioner to see if the wear pad is still with in spec's, all I need is a new gasket when i put the cover back on. I probably will add the to my winter project list along with replacing the drive belt.
The last several years I have not been riding much,,,the GF lost interest in riding, so I found a riding buddy who has a 06 dyna and we plan to take a couple of day rides in the near future. I needed to get a new Bat. and front tire and tomorrow I have a new wind screen to pick up and install. When that is all done I will be set to go,,,my friend did not have a riding buddy either and he is ready to do some miles,,,,I think I need to get another GF who like's riding a MC,,,I see all these other guys with pretty girls riding with them,,,,pretty girls make riding even more fun
Thanks
Every engine requires maintenance. Did you expect the brake pads to last infinitely?
with only 23k miles on a 10 yr old bike, does your belt look like it's drying out? Cracking? Showing signs of severe wear? I mean, this isn't rocket science. If it looks like it should be changed, change it.
Useful miles? You only ride on avg 2300 miles a year. What do you consider "useful miles"? Motorcycles preserve one's sanity. Every mile I do is one mile closer to nirvana.
I think Darwin said it best when he said "Use it or lose it."
