Wider tire on FXD?
Stock
19x2.5
100/90-19
Max
21x3.5
120/70-21
I know the 100 and 120 are the width in cm, but I don't know what the other numbers mean.
19x2.5 means 19 inch diameter rim, 2.5 inch wide. 100/90 means a 100mm wide tyre (4 inches as near as dammit) with 90% profile. This is your stock size rim and tyre.
The maximum size rim you can fit is 21 inch, 3.5 inch wide, with a 120mm 70% profile tyre.
I don't think this answers your original question! Did you want to know the widest tyre you can fit on your current 19" rim? Looking at Avon's website, they do a 110/90 Venom that will fit, which is actually 119mm wide when fitted. Also a 110/80 Azaro-ST which is 109mm wide fitted. They make a 120/70 Cobra, but that requires a minimum 3" wide rim and is 123mm wide fitted. A Venom looks the best of those.
You could look at other brand websites to see if they have anything you fancy. A word about fitted widths, which is that in my modest experience they can vary several mms from what is stated!
Hope that helps a little.
I think that while I could go wider, neither HD or Dunlop will recommend anything due to liability issues.
Appreciate all the feedback on this.
