Dyna Error Codes Help Please
Old Sep 8, 2010 | 04:22 PM
AFHuey's Avatar
AFHuey
My first impression would be that you have an air leak in your intake. But, that won't cause your o2 problems because you would be running rich.
An exhaust leak will cause you to get these errors, but I highly doubt that both your pipes are leaking. One, I would say ok...but both....yeah not likely.
Did you install the slip-ons? Did you loosen then pipes at the heads for any reason?
Old Sep 8, 2010 | 04:26 PM
SC-Longhair's Avatar
SC-Longhair
On the p0132/0154 codes...check to make sure your o2 sensors are tight. They may be loose allowing air into the system causing the system to see a rich (high) condition. Also, check the MAP sensor is tight.
Old Sep 8, 2010 | 04:30 PM
AFHuey's Avatar
AFHuey
SC, loose o2 sensors would allow more air in and cause a lean code in your ECU....which would in turn cause it to try and enrichen it.....So the ECU would see a lean condition, and try to enrichen it. I'm pretty sure that's what you mean to say but just worded it differently.
Old Sep 8, 2010 | 04:32 PM
SC-Longhair
Yes Huey. Thanks for the correction.
Old Sep 8, 2010 | 10:01 PM
kite's Avatar
kite
i have the p0108. replaced map sensor and still got it. no one has figured out mine. HD techs seem to think its no big deal.
Old Sep 8, 2010 | 10:09 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
TC96...my guess is you need a tuner...or at least get a SE air cleaner and the factory download.
Old Sep 8, 2010 | 10:18 PM
editbrain's Avatar
editbrain
Did you get a check engine light before you found these codes?
Old Sep 10, 2010 | 09:00 AM
SC-Longhair
Did that info I sent you help with troubleshooting? Figure out the cause yet?
Old Sep 10, 2010 | 11:51 AM
GTCycle's Avatar
GTCycle
1st Gear
Have checked the O2 sensors to make sure they're tight. Haven't checked the map sensor yet, will do that today. Yes the check engine light came on before getting the error codes. No leaks anywhere, have checked the whole bike over.
SC- haven't had a chance yet to look over the info you sent. Will be looking at it this afternoon. Busy day in the shop yesterday!
Old Sep 10, 2010 | 12:10 PM
SC-Longhair
Better to be busy than bored off your butt.
kch112654
Oct 13, 2018 07:25 AM
UKNixter
Dec 14, 2016 08:47 PM
Highgrade
Oct 1, 2015 06:57 PM
RustyCage
Aug 10, 2015 12:21 PM
r0senberg
Aug 9, 2013 09:07 AM
