Shift rod bolts?
Old Sep 21, 2010 | 08:26 AM
ifishwalleye's Avatar
ifishwalleye
Default Shift rod bolts?
hello,
I purchased a used set of forward controls, what i don't have is the bolts that connect the shift rod to the linkage. the rod is the custom round with the
ball ends on it (33815-06).
can you tell me if the bolts used on this are a shoulder bolt
so the nut does'nt tighten against the the ball or if it does go tight and the ball just moves with it? i looked on the HD website but can't tell by picture.
thanks
ron
Old Sep 21, 2010 | 12:57 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
2003 Dyna Models with fwd ctrl shifter rod use:
HD p/n 4017 bolt (bolt, 5/16-18 X 1 hex. hd. grade 5 steel)
HD p/n 6016 washer (washer, 11/32 X 1-5/16 X 5/8)
HD p/n 7507 acorn nut (acorn nut, 5/16-18 X 5/8 X 1/2 hex)
To be sure if these parts will fit your bike, take out your vernier calliper and do some measurements I'd say....
Old Sep 21, 2010 | 05:27 PM
ifishwalleye
Thanks for the reply.
mine takes a 5/16-24 thread. i just was'nt sure if i tghten the nut tight against'
the ball joint. i assume thats what i need to do and the ball will move with
the shifting rod when i shift. it just seemed a little stiff when i tried moving the
ball joint with my fingers. when I took it out of ups box last night.
PrkChps
Jul 23, 2013 12:52 PM
dmpjr
Mar 4, 2013 01:56 PM
rwt
Dec 16, 2011 07:14 PM
Legalcarry
Feb 15, 2009 09:39 PM
swipter
Jul 13, 2007 10:23 PM
