Scraping primary cover on ground
I was surprised to learn that you don't have to be a knee dragger to get results. I would first suggest just trying to dip your head towards your inside hand. I was surprised how much this little movement brought the bike back up. It's still a work in progress and I'm working on shifting the entire body towards the inside of the turn. IMHO, it's more difficult on an 800 lb bike that on a 400 lb bike.
It's definitely a learned art and I wouldn't recommend it for everyday riding but I want to have it available for the times I'm pushing my limits and may need something to get me out of trouble.
Guess I'll be upgrading from the stock shocks soon and practicing on my cornering techniques.
My first observation was that the butt slide produced a wobble in the front end because of the torque on the handlebars. I assume with practice this will go away. So because of that the rest of my experimenting did not include sliding my butt to the inside of the corner I was setting up for.
So I just shifted my body weight to the inside of the curve. It was hard to tell if it helped or not initially because I ended up scraping both foot pegs, and these curves were'nt really familiar to me so I couldn't say if I was going through them faster than I was able to before.
So I tried experimenting another way. I would go into a corner in my usual fashion (not leaning my upper body into the corner), then in the middle of it, shifting my body. I found that I had to set the bike more upright to maintain my line. When I reversed it, the same thing: I'd go into the corner leaning my upper body, then switching to not - I'd have to lay the bike over more to keep my line.
So bottom line is, even though it still doesn't compute in my head, how it works, it apparently does.
Thanks for making me a better rider!
Steve
At that spot the transition had already begun of a weight shift to the right for the very soon to occur right bend just ahead. Had been way farther off the seat in the long turn which is why the left peg was glowing red hot, as it was driven hard on the pavement for a couple of hundred feet. The bottom of my left boot had a nice furrow melted into it by the red hot peg.
