Inspection sticker plate
Old Sep 15, 2006 | 01:14 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default Inspection sticker plate
They put my sticker on that plate that is boldted where my forward will go. where else can that plate go? Anyone had to move it?
Thanks
Old Sep 15, 2006 | 01:40 AM
notorious's Avatar
notorious
Default RE: Inspection sticker plate
I've seen them on the lower fork next to the brake caliper.
Old Sep 15, 2006 | 09:51 AM
kimo's Avatar
kimo
I dont have the plate. I carry the sticker in my wallet. Guess thats legal i havent been stopped.
Old Sep 15, 2006 | 10:00 AM
KeithB's Avatar
KeithB
ORIGINAL: kimo
Are you in New York?
Old Sep 15, 2006 | 10:16 AM
soup48's Avatar
soup48
Can you relocate the sticker to the upper fork where there is a triangle piece with a hole. I have seen this on some bikes at the dealers, on a used bike.
Old Sep 15, 2006 | 10:41 AM
HOGRIDA_06's Avatar
HOGRIDA_06
At least you got a plate, my stealer slapped my sticker right on the fork. I'd leave it there. If you go w/ forwards the bolt should be long enough to catch enough thread with the plate being an extra spacer.
Old Sep 15, 2006 | 10:53 AM
JollyRogers's Avatar
JollyRogers
Mine is on the lower part of the fork, left side. Hold on and I will go look at it...It is mounted on left side, facing towards the rear on the lower break bolt.
Old Sep 15, 2006 | 10:58 AM
rob_will's Avatar
rob_will
I bought my inspections sticker, sprayed it flat black to match my lower forks and attached it to my brake caliper bolts. Looks really clean
Old Sep 15, 2006 | 12:02 PM
Geronimo's Avatar
Geronimo
I have my sticker on the forks and I wish I could put it somewhere else. I WAS under the impression that in NY it HAD to be there....now I will look for alternatives....
[IMG]local://upfiles/5110/D9B1E851F1B747C99E66CB69D74227D3.jpg[/IMG]
[IMG]local://upfiles/5110/940F0C1DB22A4ECFA4D9800E7E5F7663.jpg[/IMG]
Old Sep 15, 2006 | 06:51 PM
cj_slowdown's Avatar
cj_slowdown
<kimo”>
<”I dont have the plate. I carry the sticker in my wallet. Guess thats legal i havent been stopped.”>
I am glad you don’t live in PA : - )
All kidding aside, cops here in PA if you showed them you inspection sticker coming out of your wallet, you would be in the back seat and the bike on a roll-back : - )
I know someone years back that pulled that (w/a car) inspection sticker, must be put on by a license PA inspector on the left side down tube (at least it’s the ugly lean side : - )
No bolt on plates, if a plate is used must be welded on the left side.
cj
