Starting Problem
Old Oct 10, 2010 | 02:46 AM
Supamag's Avatar
Supamag
Default Starting Problem
Hi All,
I had my battery run down on me due to lack of use for about 6 weeks; I have recharged the battery but now the bike doesn't start I get a series of clicking noises and the speedometer shows a message 'Side Stand'. Any ideas as to the problem???
I have checked the bike over with the stand both up and down the message is the same.
Paul
Old Oct 10, 2010 | 07:07 AM
ynots's Avatar
ynots
My guess is the clicking noise is from lack of voltage going to the starter. No advice on the side stand message... faulty sensor?
Id suggest getting a battery tender for your scooter
Old Oct 10, 2010 | 07:33 AM
bobnehoc's Avatar
bobnehoc
It sounds like your battery is shot. What kind of bike are we talking about and how old is the battery? +1 on the battery tender, use mine everyday and I never have a starting problem even in the winter. Never heard anything about a side stand, but it is possible that the battery is in such bad shape that the sensor is is malfunctioning. I would replace the battery and definitely get a battery tender.
Old Oct 10, 2010 | 07:55 AM
shopratles's Avatar
shopratles
3rd Gear
A good battery should last more than 6 weeks if the weather is decent (extreme cold and heat will kill a battery). Don't know much about battery tenders, I just kick-start mine when the battery is low and it fires right up. Good luck.
Old Oct 10, 2010 | 08:43 AM
Supamag's Avatar
Supamag
Thanks for the tips guys,
Bike is an 09 Fatbob; don't have the means to plug a battery optimiser in near the bike as it is stored outside. I have had the battery charging overnight, showing 12.7v on the meter. I think it may be to do with the sensor on the jiffy stand or with the clutch lever as I had the left hand switch housing apart around 6 weeks ago looking at swapping the grips out. If I try to push the bike when it is in gear and have the clutch pulled in it doesn't move almost like the clutch lever isn't pulled in.
Will have to look at getting the bike recovered on Monday to local garage.
Old Oct 10, 2010 | 09:00 AM
Grendel4's Avatar
Grendel4
Fairly common on just about any standard transmission. Wouldn't worry about it right now.
The Jiffy Stand light is on International models only, AFAIK.
Batteries can take a dump for no reason at all. They can show a 'surface charge' and fool you, too. If you think there is a dead short or a draw on your bike, that would certainly cause the battery to die but it should come back after a good charge. Usually. If it doesn't...... Batteries will short out on you sometimes if you let them go all the way down. Sometimes they'll short out on you just because they're in bad mood.
And, this is just my opinion, but I'm not a big fan of keeping a battery at 100% charge all the time. Just me, I guess. If your bike sits a lot, just run the extension cord and battery charger out to it every couple weeks and gently bring it up to full charge. Remember, motorcycle batteries are not very big. They're (what) 300 CCA? Around there? My lawn mower battery is that size and it's only turning over a 26 HP engine.
Just my $.02 -- Not sure it's worth even that.
Old Oct 11, 2010 | 06:04 AM
Supamag's Avatar
Supamag
Got the bike started today
I put the battery on charge with a different charger and it appears fine now. Looks like the battery needed a long time to get to peak condition as it was on charge for a total of around 48 hours.
Paul
DeeRides
Dec 18, 2013 09:54 AM
TAHOE GUY
Dec 12, 2012 10:48 AM
Renback
General Topics/Tech Tips
Feb 13, 2010 08:20 AM
tfuller
Apr 15, 2009 11:46 AM
HDF Tech
Electrical/Lighting/Alarm
Dec 12, 2005 08:45 PM
