Replacing Cobra II Light Assembly
Old Oct 10, 2010 | 07:40 PM
X90's Avatar
X90
Default Replacing Cobra II Light Assembly
Purchased a Cobra II bullet headlight and wanted to swap reflector and lens with the original. The problem I am having is I can't remove the trim ring to remove the cobra's lens. I removed the set screw, and tried to gently remove the ring with a screwdriver, but it won't budge.
Has anyone else had this problem trying to swap lenses or changing the bulb?
Need help before I switch to a bigger tool and f... everything up.
Old Oct 11, 2010 | 02:45 AM
X90's Avatar
X90
Smile
Bump.
Old Oct 11, 2010 | 07:21 AM
weeT's Avatar
weeT
I haven't tried it yet, but I read on here somewhere that people put tape on their thumbs (sticky side out) & use that to help turn the ring. Also, you could try double sided tape....may take a helper to give you 2 more thumbs...!!
Old Oct 11, 2010 | 10:49 AM
X90's Avatar
X90
Thanks.
I'll give it a try and see what happens.
jousley
Nov 18, 2016 02:56 AM
Romark
Dec 26, 2011 08:15 PM
bikerlaw
Nov 7, 2011 07:46 PM
Ky Windage
Sep 1, 2009 12:01 PM
OlDrifter
Oct 16, 2007 01:14 PM
