Bullet headlight, yeah I'm stupid.
Old Nov 6, 2011 | 07:46 PM
bikerlaw's Avatar
bikerlaw
Default Bullet headlight, yeah I'm stupid.
So based on the rave reviews I have gotten on this very forum, I went ahead and purchased the Eastern Performance bullet headlight for my Springer. I really like the light... a lot. It flows great with the Springer and is a solid piece. So as most of us do, my first thought was to install a Silverstar bulb for better lighting. I swear to God, I can not figure out how to get this light apart. There is a small set screw in the bottom which I removed, but nothing I seem to do will get this thing apart. The reason I spent the extra money on this light was that it is advertised that it uses a replaceable H4 bulb, so I know that it comes apart. Any help from those who have this light is appreciated. I am afraid I just need to really pry the front ring out with a screwdriver, BUT if I do that I will certainly wreck some chrome. It would seriously **** me off if I crack the housing or have to gouge up the new chrome to do this. Advice needed.
__________________________
Old Nov 6, 2011 | 08:10 PM
SteveO-ll's Avatar
SteveO-ll
Use a suction cup on the lens to give you grip and leverage...................
They usually sell them as dent pullers at the auto parts store, or get one from a glass supplier.
PS: Hope that helps
Old Nov 6, 2011 | 08:14 PM
JustDave71's Avatar
JustDave71
see that trim ring inside the housing?
Back off or take out the set screw
facing the light, grip that ring with your thumbs and turn the ring counter-clockwise. It's a royal PITA but it will give. I'm sure there's a pro way to do it, maybe email them? I've just always done it this way.
once that comes off, there'll be another ring. It'll have detents. I just take a punch or small phillips that fits in one of the detents and turn the ring cc.
getting 'em on is just as much fun as takin 'em off.
Old Nov 6, 2011 | 08:16 PM
Shovelhed's Avatar
Shovelhed
Just spin the ring counter clockwise. The one that holds the lens in. It might be a little tight, but shouldn't be that bad.
Old Nov 6, 2011 | 08:58 PM
bikerlaw's Avatar
bikerlaw
WOW, no, like really... wow. I never, would have figured that out. It never even dawned on me that the ring was threaded. Like posted, it took a while, but once it budged the first time, I was able to use rags and spin the outer ring off and then get to the inner ring. Well, the Silverstar is in and I put plenty of anti seize on the threads. Knowing that these Silverstars don't last long and its just a matter of time till I need to do this again, I wanted to make sure that if I was stuck in some Walmart parking lot at 2:00am that I could get the thing back apart. Thank you guys sooooo much for the insight and replies.
_____________________________
Old Nov 6, 2011 | 09:50 PM
DonN's Avatar
DonN
Looks nice. I had the same problem with my bullet headlight.
If you need more light, a HID and ballast should fit in there nicely, or can plug in a LED if ts a 5 3/4.
Old Nov 7, 2011 | 07:42 PM
PsTaN's Avatar
PsTaN
I've been thinking about one of those lights .... always wondered whether they were a real deal based on price and the actual quality.
Looks terrific on the Springer!!
PsTaN
Old Nov 7, 2011 | 07:46 PM
bikerlaw's Avatar
bikerlaw
Thanks guys. I thought about the HID, but for now I just installed the Silverstar. There is VERY little room in the back of that light so I'm going to run just that for now, or until I figure out what HID to attempt.
jousley
Nov 18, 2016 02:56 AM
kiltiemon
Jun 20, 2015 04:47 PM
X90
Oct 11, 2010 10:49 AM
mrthinkshesfunny
Feb 25, 2008 06:22 PM
OlDrifter
Oct 16, 2007 01:14 PM
