automatic compression release
Old Oct 19, 2010 | 11:06 AM
JRK5892's Avatar
JRK5892
i have both in my motor as well and you do not need them on a stock motor
Old Oct 19, 2010 | 11:42 AM
wideglidebob's Avatar
wideglidebob
when i did my 95 build i put in the comp release sure glad i did i diden`t put in the automatic ones my research showed prob with them, so i put the s.e. push in, if i forget to engage them i can tell starter really drags, when i do engage them it starts up with one push, no drag at all, but i am over 10 in comp
Old Oct 19, 2010 | 04:50 PM
dyna rider's Avatar
dyna rider
Default Compression Releases
If you feel like you gotta have em, get the manual ones...no wiring and easy to use.
Old Oct 19, 2010 | 05:00 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
have your battery load tested and get a battery tender.
Old Oct 19, 2010 | 05:30 PM
JRK5892's Avatar
JRK5892
ooh ya mine are manual, you just reach down and push them in prior to start... is easy i had them installed when i did my head work... 100% worth it!
Old Oct 20, 2010 | 09:14 AM
ssls6's Avatar
ssls6
First, thanks for all the advice. My battery is fine and it's not a question of "must have them", it's more a question of "want them because I know what they do and even at 96" it's worth it long term". I think my bike has the connectors already in the wireloom and my TTS is capable of turning that function on.
Is there a company out there that I can send my heads to for the conversion?
Thanks,
Richard
speakerfritz
Jul 14, 2012 01:08 PM
skjskmata
Mar 19, 2012 05:22 AM
thelawcc8
May 3, 2010 04:40 PM
racerdave
Oct 29, 2009 04:20 PM
05 HD Deluxe
Exhaust System Topics
Aug 12, 2007 10:21 AM
