Electrical question
Old Oct 22, 2010 | 09:59 PM
roofer's Avatar
roofer
Default Electrical question
I scored a 2005 wide glide dash that has every thing in it and I want to put it on my 03 lowrider but the connectors are differant, my biggest problem is the speedo is there a way that I can use a 05 connector on a 03, anyone out there know Thanks. Also the dash fits the tank just fine just need to do a few mods to bolt in on,
Old Oct 23, 2010 | 06:20 AM
sniper77's Avatar
sniper77
If it has the same number of pins then just follow the color code and switch the pins from you existing plug to a new plug.
If the color code doesn't match, your out of luck.
Also the '05 Wide glide tank is larger than the '03 Low Rider tank and the dash is not interchangeable.
Old Oct 23, 2010 | 07:35 AM
8541hog's Avatar
8541hog
Are both from carb bikes? If so it should be pretty easy.
The dash should be interchangeable if you have the mounting plate that goes on the tank.
Get a wiring schematic from each bike and match the pins up, it should be pretty straingt forward if you can follow the schematic.
Old Oct 23, 2010 | 10:03 AM
roofer's Avatar
roofer
I got such a good deal on it that I might just re sell it and go for the right year I didn't relieze that they changed the speedp and idiot lights in 04
Old Nov 9, 2010 | 05:42 PM
roofer's Avatar
roofer
Here are the pics
georgeplg
May 24, 2011 09:04 PM
Gladiator72
Feb 2, 2011 08:01 PM
glide05
Jul 10, 2008 09:38 AM
Genxshaman
Apr 23, 2008 02:41 PM
98fxd
Aug 24, 2005 07:58 PM
