No more Floppin' Fob
Old Oct 26, 2010 | 10:55 AM
SailorDon's Avatar
SailorDon
Default No more Floppin' Fob
Originally Posted by bobnehoc
I also keep the ignition key and the fob on the same ring. I hated the fact it was flopping in the breeze everytime you ride. Poor design from the moco that it is not removeable and you have to leave the key in. Luckily there is a quick fix for it, I just ground the nub off of the key and it is now removeable.
Aftery reading this post to the topic on "Bloody Security system" started by 'Foxster', I did the same key mod that 'bobnehoc' did. I rode with the key and fob in my pocket for the first time in 7,000 miles and over a year. Why did Harley Davidson make the original key design so it couldn't be removed when the ignition was on? I thought that nub was required to make the key work in the ignition. Obviously not. I ground off the nub this morning and no more "Floppin' Fob" for Sailor Don. I'm a happy biker.
Now I have to see if I can polish the frame around the ignition to the original gloss.
Old Oct 26, 2010 | 12:14 PM
bigmikaele's Avatar
bigmikaele
nope... I've tried. I stopped keeping my fob on my key and keep it in my vest pocket all the time, but have that same dull mark and have tried to do everything save polishing compound to get it back to the same shine and I have gotten it pretty close but no cigar.
Old Oct 26, 2010 | 02:16 PM
ord sgt's Avatar
ord sgt
I have always kept the fob in my watch pocket. The key goes there too whenever I park the SB. The thought of the fob banging around in the wind while riding never seemed right to me. Having the little circle clip break and the fob disappearing along the road was a cause of distress.
Old Oct 26, 2010 | 02:21 PM
editbrain's Avatar
editbrain
I use the key chains that you can separate. Got it at a box store for a dollar. Keep the fob on one end with my truck keys, and the Harley key on the other. Take the key chains apart use the key for the bike and the other keys go in the pocket. What is the big deal about that?
toastman's Avatar
toastman
i put a thicker key ring on the fob because i figured the wind would break the flimsy one that HD gave me.
seperating the fob/key for me really isn't an option as i'm prone to misplacing things when they're seperated.
to keep it off my frame i put one of those cheap caribiners (clips the climbers use) on the ring and clip it onto one of the cables or lines that are over by my ignition.
it limits the amount of movement the fob has, so it doesn't rub the frame.
Old Oct 26, 2010 | 04:15 PM
turbostang's Avatar
turbostang
+1 for editbrain's route. I had a quick disconnect for the key, and the garage opener and fob stayed on a clip on my belt. Until I got the Fat Bob, and now they all stay in my pocket!
Old Oct 26, 2010 | 04:25 PM
maryland blackout's Avatar
maryland blackout
Why do they keep adding more unecessary electrical? Next thing you kow they are going to have a numerical keypad on the side of the tank to unlock the bike and fingerprint recognition to start it. Heck, they might already have that for all i know. Sounds like the whole coding with your blinker buttons, or however that works, is getting pretty close. What's wrong with using your key to start the bike, and the built in neck lock for security, end of story?
Old Oct 26, 2010 | 04:29 PM
JRK5892's Avatar
JRK5892
i must have missed this, what do you do? just take off that little tab on there and you can pull the key out?
i have a magnet on the back of mine, works great!
Old Oct 26, 2010 | 05:03 PM
fskitch's Avatar
fskitch
Yeah I think I saw it in the under $50.00 or less mods. You just glue or a thin magnet to the back of the fob. They even have magnetic strips with adheasive. Then just place the fob on the frame while its attached to the key ring. No rattle or scuffs.
Old Oct 26, 2010 | 05:23 PM
DYJ's Avatar
DYJ
Talking
Originally Posted by editbrain
I use the key chains that you can separate. Got it at a box store for a dollar. ?
Ditto.... except I got mine off the Snap On truck, cheepest thing I ever bought off there
