What is that?
Old Oct 28, 2010 | 01:02 PM
FatJohn's Avatar
FatJohn
Question What is that?
My used 2008 Fat Bob came with custom controls. So the left side shift linkage looks like this...
In the yellow circle, you see that there's an extra lever or connector or something and another tab above it. Was this part of the original linkage? Should it be connected to something now? Closer look...
Should I remove that top tab?
Old Oct 28, 2010 | 01:11 PM
matts Dyna's Avatar
matts Dyna
6th Gear
The lever that goes through the primary looks like it was for the mid controls that come on the bike stock. The other one, not to sure. The lever isn't a big problem since it's not hooked up to anything. Some people just don't want to remove the inner primary cover to take the lever out, so they leave it like that.
Old Oct 28, 2010 | 01:20 PM
tscreener's Avatar
tscreener
Looks like its to keep the stock shaft from moving around.
Old Oct 28, 2010 | 01:28 PM
terrible1one3's Avatar
terrible1one3
Those should be connected but it looks like the bracket going to the crank is the wrong one.
That bracket holds the mid shift shaft that is the **** sticking out of the left side of your primary. That is where the stock shifter use to be.
Old Oct 28, 2010 | 01:43 PM
Mascman's Avatar
Mascman
That is a hideous way of hiding the stock shift shaft. LOL
I think you can make something work that would look a little better, unless it doesn't bother you, then leave it be.
Old Oct 28, 2010 | 03:50 PM
JRK5892's Avatar
JRK5892
whoever did the contorls installed htem the easy way and did not remove the shifter linkage there
Old Oct 28, 2010 | 04:24 PM
chuckdizzle's Avatar
chuckdizzle
That is the most awesome short cut I have ever seen for the mid shifter shaft! I bet it doesnt rattle though.....
Old Oct 28, 2010 | 06:13 PM
kk6pg's Avatar
kk6pg
Tacky. I cant think of another word for it.
Old Oct 28, 2010 | 06:40 PM
BeavisRules's Avatar
BeavisRules
It is definately better than the piece of wire that I used for a few months. LOL
Old Oct 28, 2010 | 06:52 PM
maddghost's Avatar
maddghost
You nailed it!
