How long to "relearn" new pipes?
Old Nov 1, 2010 | 12:56 PM
  #31
editbrain's Avatar
editbrain
Let me put it this way. AFV has to be reset every time you flash your bike. Reset "AFV" values when you flash the bike. If they were not learned then you would not have to reset the values.
Also when you watch your sensors you will see the Adaptive Fuel values go over 100%. That means that it is comparing the cells, and adjusting/learning the new AFV for the block of cells.
Yes, AFV is learned.
  #32
Garcou's Avatar
Garcou
Make sure your slipons are not leaking! Best thing to do is use some high temp silicone and a rivet on the bottom
Old Nov 1, 2010 | 01:37 PM
  #33
Faast Ed's Avatar
Faast Ed
And the hostile coments between "Ed" and myself ( post count remarks) were from another thread where Faast Ed expounded on how engineers did not know nearly as much as "technicians" that worked with their hands.( and having only a few posts I could not possibly know what I was talking about!)
I don't usually comment on post counts. You have me confused with someone else.
That, or you are flat out lying. I looked for the thread and could not find it. I sure don't recall commenting on post count.
I'd only do something like that on a multiple page thread with the OP having 2 posts, to point out his question was meant to stirr the pot (and warn others of it).
I did indeed comment about the engineers I work with, that rufuse to listen to the guys who are "hands on" working on the products that the engineers had only seen in books.
I stand by that comment.
As far as ecm's that learn,...... I've asked this board numerous times if something had changed in the 2010 - 11 ecm's and never got a solid answer.
If the new one's can learn a microscopic amount, I'd still like to see more than "word of mouth" information stating so.
Show me something solid. I want to learn.
Old Nov 2, 2010 | 09:30 AM
  #34
Grendel4's Avatar
Grendel4
That might say more about the Company you work for than it does the individual Engineers.
Many modern Companies are very serious about 'Upward Communications'. Some of the old dinosaurs are still stuck in the downward communication only syndrome. Bad on them.
Maybe there's serious commuication problems between employees and Management. Maybe it's not entirely Management's fault. An example might be, while the workers at Toyota, Honda, Nissan and BMW were organizing into quality and production improvement groups all through the last twenty years or so, the UAW was organizing a strike for more sick days. How's that working out for the 'Big Three'? Big Three, huh? Laughable.
Maybe the Engineers have their hands tied by Management. Maybe Management is run by Accountants. NEVER a good thing. Maybe the Engineers spend so much time trying to cut corners for cost reasons that they've given up on being Engineers.
Or maybe they're buttheads. But Ive never seen an entire group of people that were buttheads. A high percentage sometimes, but ALL of them? Nah, there's something else going on behind the scenes.
Old Nov 2, 2010 | 11:50 AM
  #35
traveler's Avatar
traveler
The bikes adjustability to tuning has a small range. You basically went outside fo the adjustability range, so a tune is in order. If you can still get a Stage 1 download, that will fix it, otherwise you will have to have a DYNO tune performed.
Popping indicates a lean condition, and these bikes in a stock tune are set so that when the throttle is released, the computer goes "full lean"...this is EPA anti-pollution/anti smog Enviro-**** stuff.
~Joe
Old Nov 2, 2010 | 12:20 PM
  #36
Grendel4's Avatar
Grendel4
~Joe
Now that's interesting. Something I didn't know but am pleased to learn.
Explains the 1st to 2nd pop that I get.
Just kinda asking, but on decel, when there's no load on the motor at all, would the lean condition be a non-factor except for the unpleasant noise?
Old Nov 2, 2010 | 01:49 PM
  #37
dondee's Avatar
dondee
Now if you boys can put down those rulers for a minute or two, here's an update from me, the OP: after around 100 miles or so since the pipe change the decel pop seems to have gone completely away.
While I've had enough Harley's to know that noises, symptoms and other behaviors can come and go for some reason, any reason or no reason at all it kinda makes you think maybe that Rush guy a few posts back might have been on the money, huh?
After all, they're in the business...
Old Nov 2, 2010 | 01:56 PM
  #38
traveler's Avatar
traveler
Will it hurt anything?....probably not, but if you are going to tune the bike, it can be easily remedied. Engines in a lean state make MORE power, but it is destructive to the engine, and causes MUCH higher temps. Too lean and it loses power and overheats. This is why the new dressers run so hot....EPA reg's and alot of weight on a lean tune. Adding a touch more fuel to the tune makes things just work better. Cooler engine temps, more power, resulting in more timing, and MORE POWER.....but more emissions, so the lefties aren't going to like you messing with the stock tune.
~Joe
Old Nov 2, 2010 | 01:59 PM
  #39
traveler's Avatar
traveler
Good to hear.....I'd be interested to know how much adjustment the tune made to get it right, and if there is still adjustment room for altitude changes etc., as the adjustment range is set in place for altitude variances, temperature changes etc.
~Joe
Old Nov 2, 2010 | 02:13 PM
  #40
editbrain's Avatar
editbrain
How is the bike set to go full lean when there is a decel enleanment table for variations in temperature? Granted the DE only acts for a brief moment when the throttle is off.
I would say that the pop between 1st and 2nd gear is because the VE is incorrect for those cells. I had it sometimes with my TH, but if I had the intake open some to all more air, in I would not get the pop.
