How long to "relearn" new pipes?
Old Nov 2, 2010 | 02:26 PM
  #41
traveler's Avatar
traveler
To meet EPA regulations, they had to make it so that sudden throttle release from using alot fo throttle to nothing would not result in excessive unburnt hydrocarbons being emitted. Popping means lean....and the leanness comes from going from a "load condiditon" to a very sudden "no load" condition at RPMs much higher than idle. Revving it up in neutral shouldn't do it....it has to come from being under load and suddenly dropping the load. If it pops in neutral even, then it is REALLY lean.
I'm not an engineer, I simply learned this stuff from my personal experience. My 'Glide was a popper before we added fuel in that portion of the curve. If I'm wrong, fine....but I DO know popping means LEAN.
~Joe
Old Nov 2, 2010 | 02:42 PM
  #42
editbrain's Avatar
editbrain
It pop when rich as well. Just saying.
Old Nov 2, 2010 | 04:29 PM
  #43
Rush Racing Products's Avatar
Originally Posted by dondee
Now if you boys can put down those rulers for a minute or two, here's an update from me, the OP: after around 100 miles or so since the pipe change the decel pop seems to have gone completely away.
While I've had enough Harley's to know that noises, symptoms and other behaviors can come and go for some reason, any reason or no reason at all it kinda makes you think maybe that Rush guy a few posts back might have been on the money, huh?
After all, they're in the business...
Glad things worked out! A hundred mile ride seems like an easy fix to me.
Ryan
Old Nov 2, 2010 | 04:55 PM
  #44
Faast Ed's Avatar
Faast Ed
Moreso on accel, than decel.
Old Nov 3, 2010 | 09:56 AM
  #45
editbrain's Avatar
editbrain
I have had a rich bike pop on decel. I have had a rich bike sputter and back fire on accel. Bottom line when it isn't right; it isn't right, and needs to be addressed.\
I too am curious how much the stock ECM is had to compensate to fix the issue, and if it at the edge of its adjustments. Therefore leaving the bike in a vulnerable state if weather or altitude change.
Old Nov 3, 2010 | 10:37 AM
  #46
Faast Ed's Avatar
Faast Ed
I would love to see some crisp clear legit documentation from the Harley Davidson company on just what exactly their ECM will or will not do, and what year these alleged changes took place.
Even though some very reputable people have said it adjusts (and it very likely might adjust), I'd really like to know the ins and outs of the newer ECM's.
This has to be a recent upgrade and I would like to know more about it.
Old Nov 3, 2010 | 10:53 AM
  #47
editbrain's Avatar
editbrain
I don't think you will get that. That information would destroy the aftermarket fuel management companies, and also limit SEPST sales. Don't you think?
Other than the fact that the device is tied to my bike. I would not trade my SEPST for any other tuner on the market. That is just me. I know that I can put whatever I want on my bike, and tune it. It is a good feeling.
Old Nov 3, 2010 | 12:54 PM
  #48
Faast Ed's Avatar
Faast Ed
I have to believe there is hard info available somewhere. The auto industry had nothing to lose by including that info in their service manuals. It was a necessary part of the troubleshooting process. Once you reset the ecm, you were advised that it would take x amount of miles to relearn. I've got a dusty old car service manual that has that included.
The fact that HD does not do this, makes me sceptical about the hearsay (no offense meant towards anyone). I want to know where the "experts" got their information about our ecm's learning process, and what year they started "learning and retaining the learned info".
There is no "conspiracy" from the Moco to hide info. If your ecm needs time to relearn, that is critical info for them to put in their book. Period.
Sure the dealers and salesmen might BS you, but the moco is too big for that. Either their ecm's learn, or they don't. There has to be info out there to confirm what they do.
Until someone can post a credible link to info authored by HD about their ecm, this whole thread is a waste of bytes.
Edit: I don't have access to a 2011 service manual. Can someone please look at one and see if there is any info in there related to this? That would surely clear some of the speculation.
Thanks in advance.
Old Nov 3, 2010 | 01:45 PM
  #49
editbrain's Avatar
editbrain
Faast Ed, I don't mean to bring up a touchy issue, but the AFV does reset, and learn on the Harley ECM. I don't know how long it takes, but from what I can tell by tuning with the Smart Tune, I would think that it would be completed learning for your cruising speeds in about 25 miles or less. That is because you only have to ride in the cell for 5 to 10 seconds for the computer to get enough data to adjust. Again I am no expert, and I didn't stay at a Holiday Inn Express last night ( a little humor there ).
I would also like to know, and I am really thinking of making an offer to use an INDY's dyno with a A/F sniffer to trial and error my bike, and also learn to tune better with the SEPST. If I can do this then I could have a great side job, and maybe earn enough to build that custom sporty I always wanted.
And in my travels if I find out the answer. I will definitely let you know, and also let the board know.
Old Nov 3, 2010 | 02:15 PM
  #50
Faast Ed's Avatar
Faast Ed
My question all along has been: "does is go back to default factory settings upon shut-off" (or does it learn and retained the settings from the closed loop sensor input). I always knew it adjusted to the sensors, but have always been under the belief that it went back to original settings upon shut-down. I'm getting to the point that I really don't care anymore. I was curious, but I'll never have a stock bike again, and least not long enough to where it would matter whether it learned it's abc's or not. LOL I was just curious.
My last bike had a Power Commander and my current bike has a SERT. I liked them both but the SERT by far has a lot more to offer. No doubt the newer stuff would be better yet!
