A little tank help?
Old Nov 12, 2010 | 02:31 PM
FiremanQ14's Avatar
FiremanQ14
Default A little tank help?
I have an 05 Super Glide, the speedo sucks! I am considering swapping the tank out to one of the models that has the speedo built into the tank.
Anyone here done this? If so, is it too complicated?
Thanks!
Old Nov 12, 2010 | 03:38 PM
JaronB's Avatar
JaronB
I know it's been done. I wouldn't think it will be to tough and you can probably get a Street Bob talk pretty cheap on ebay!!
Old Nov 12, 2010 | 07:16 PM
U-234's Avatar
U-234
I have a new black '04 Low Rider tank. I bought for my Project Street Bob. Painter said he would rather fix the dented stock tank.
PM me if you want to get started on your own project.
Old Nov 13, 2010 | 07:03 AM
super05's Avatar
super05
can be done and not too difficult, just $ consuming. All dyna tanks for 04 and later should fit, there are 3 sizes total including yours. A bit of rewire is needed for the lamps and fuel gauge. you need to remove the fuel pump inside the tank and transfer it (if you have FI).
It's going to cost 300-500 in addition to the tank. that seems high - but add up the following
parts:
tank
dash
tank plate
speedo
idiot cluster
fuel gauge
gas cap
gaskets
screws
Old Nov 13, 2010 | 11:52 AM
FiremanQ14's Avatar
FiremanQ14
Thanks for the help. I already dont have a speedo, so Im out that cost anyway. Going to cruise the local shops and see what I can find.
Old Nov 13, 2010 | 08:16 PM
U-234's Avatar
U-234
Default Tanks: What Fits What?
Thought I would post this because it is a tank thread.
The Dynas have used 3 tanks from 2004 to 2010.
Tank 1 = FXD, FXDX, FXDC, ‘07 FXDSE
Tank 2 = FXDB, FXDL, ‘08 FXDSE, '10 FXDWG
Tank 3 = FXDWG to '08, ‘06 FXDI35, ‘07+ FXDC, ‘08+ FXDF, '09+ FXDFSE
Old Nov 13, 2010 | 09:23 PM
Lennyone's Avatar
Lennyone
You can change the tank, I have a different tank on my 2005 FXDX
Old Nov 13, 2010 | 09:42 PM
07bobber's Avatar
07bobber
I have an 07 fxdb tank for sale
Old Nov 13, 2010 | 10:08 PM
rocknrick's Avatar
rocknrick
Don't use a tank from a Street Bob. Go with one used on Low Riders or Wide Glides so you can have the switch on the console.
Old Nov 13, 2010 | 10:19 PM
SURFOR Chop's Avatar
SURFOR Chop
I did a tank swap from an '04 FXDLI to my '05 FXDI ... reused my speedometer with a Street Bob console ... (I think you can use a '10-up Wide Glide console to move the ignition switch) ...
I got the tank for about $250 and including the tank, I spent less than $450 for everything but paint ....
If you do a search of my threads on the Dyna forum, I posted the details about 18 months ago ... think it was March of '09 ... I did a detailed break down of parts I used with P/N ....
R/
'Chop
