A little tank help?
Old Nov 14, 2010 | 06:46 AM
super05's Avatar
super05
doing this for $200 + cost of tank is not likely possible unless you use a streetbob tank and a used ($50) sb console. in that case you still need a tank plate and gasket + idiot lamp cluster. This is by far the cheapest route assuming you use a sb tank and can find a used sb console.
the 2010 wide glide console is north of $200 all by itself, and you have the ignition switch issue to deal with, + the other items that go with any change (tank plate, gasket, idiots)
if you get a 2004-2008 wideglide tank, the console for that is not cheap, over $150 then you have the larger speedo, ignition, tank plate+gasket, idiots, etc. over $400 for these parts combined
Old Nov 14, 2010 | 06:31 PM
U-234's Avatar
U-234
"Don't use a tank from a Street Bob."
If you notice the #2 tank on the list that I posted, the Low Rider and the Street Bob tanks are the same. Consoles and bike wiring will differ.
Old Nov 14, 2010 | 07:25 PM
ackman1968's Avatar
ackman1968
Originally Posted by rocknrick
Don't use a tank from a Street Bob. Go with one used on Low Riders or Wide Glides so you can have the switch on the console.
Olenty of Street Bobs with the switch on the conslow, real easy to do if you're willing to take the time.
tayls87
May 25, 2013 04:39 PM
ThatGuy782
Mar 27, 2012 12:06 PM
fighthedude
Aug 5, 2011 08:42 AM
ladodgerdog
Jun 17, 2007 08:21 AM
98fxd
Exhaust System Topics
Aug 23, 2005 12:44 PM
