tank swap exact materials
Old Apr 14, 2011 | 07:20 PM
fighthedude's Avatar
fighthedude
Default tank swap exact materials
Alright after a long debate I think I am going to tackle the FXD to FXDB or FXDL tank. I have found the parts list and have some coin so I think I am going to do it. Hopefully one of my final questions to you all, is does anyone know exactly what I will need. I know I can use the fuel pump, speedo but how about bolts and what not. While I have some money I don't have a lot of it. Thanks everyone who contributes. Cheers
Old Apr 14, 2011 | 08:18 PM
SuperFastGlide's Avatar
SuperFastGlide
i did the swap to a streetbob tank... all the internals of the tank interchanged... alls youll need is the tank, dash and indicator lites...and a repair manual helps... one of the best mods ive done and not really difficult...
Old Apr 14, 2011 | 08:27 PM
wolvie1892's Avatar
wolvie1892
I was thinking about doing the same mod from a 09 FXD to a Street bob, about how much would something like this cost, if you don't mind me asking.
Old Apr 14, 2011 | 08:45 PM
skip3406's Avatar
skip3406
FXD to FXDB or FXDL Fuel Tank
61705-06 Console assembly
68382-07 Indicator lamp bezel
68789-96A Indicator lamp assem.
75053-01B fuel gauge
75246-04 top plate assem.
75248-04 Fuel tank seal
+ odds & ends
Old Apr 14, 2011 | 09:04 PM
02fx4dude's Avatar
02fx4dude
Not sure about the FXDB, but the FXDL has the indicator lights mounted in the handlebar clamp, which can create headaches.
Old Apr 14, 2011 | 09:12 PM
wolvie1892's Avatar
wolvie1892
I hope you post some pics after your done with it. Give some of us thinking about doing it some hope.
Old Apr 14, 2011 | 10:03 PM
fighthedude
Cheers to you all. Hope to have this done within a month. Will document and post once this gets going.
Old Apr 14, 2011 | 11:05 PM
stev0n's Avatar
stev0n
Several have done this. I have all the parts sitting here waiting to swap when I have enough money to get the new tank painted/a dent fixed.
I have less than $300 in the whole swap. a little over $400 after body work.
I spent around $120 at zanotti's & $150 on ebay for everything including the new tank.
*warning - i placed my order at zanotti's 2 months ago & just got the last part today. So you'll have to be patient with them.
I cross refernced every part number on the microfiche at ronnie's hd website to find out what I could re-use & what I needed new.
Old Apr 15, 2011 | 05:30 AM
SuperFastGlide
i forgot... you need the gasket for the tank plate and you also need to replace the sealing bolts that fasten it to the tank....
Old Apr 15, 2011 | 06:27 AM
8541hog's Avatar
8541hog
If you buy the complete tank with guts and console for whatever you are going to change to, all you really need is some wire, everything else pretty much bolts right on.
I swapped from the WG to the SG tank, hardest part was the wiring the Dakota Digital and it was not difficult.
You can re-use the gasket for the plate and the bolts, many on here have including myself. Trick is tighten up gradually in stages in a star pattern. It is a fairly thick rubber gasket, so as long as it is not damaged you will be fine.
