fuel leak
Old Nov 17, 2010 | 02:02 PM
ric306's Avatar
ric306
Default fuel leak
took the tank off my 2008 FXDC, when i put it back on the quick disconect fitting leaked. i see a small o ring on the fuel line L, replace this? or is there an o ring in the female diconect? thanks
Old Nov 17, 2010 | 02:09 PM
ratt196635's Avatar
ratt196635
There was a thread about this awhile back but i cant find it i think its the one in the female that causes the problem but i have been known to be wrong
Old Nov 17, 2010 | 02:18 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Yep new oring should do it.
Old Nov 17, 2010 | 02:46 PM
bikertrashchad's Avatar
bikertrashchad
OK, just had this problem about 2 months ago. I took the tank off for paint and when reinstalling the tank, the o-ring pinched. There is an o-ring inside the tank-side disconnect (the female part). If you go to an HD dealership, they will only sell you the entire disconnect ($68). I tried one of the Help kits from a local parts store and the o-ring was simply too fat/big. Solution: I went to a Car Quest, who stocked two large o-ring kits (the kind behind the counter that have 50 different o-rings, took the old o-ring with me for matching, and paid $0.40 for two o-rings. If you have problems getting the match, I still have the receipt from at the house. It was a metric o-ring.
Old Nov 17, 2010 | 03:13 PM
NoLongerAmember's Avatar
NoLongerAmember
I had a leak and it was just the o-ring(s) were dry and did not seal. I put a little silicone grease on the fitting, installed and removed it a couple of times and all was/is well. Are the o-rings actually torn?
CB
Old Nov 18, 2010 | 01:20 AM
ric306's Avatar
ric306
Default fuel leak
thanks for the help, will see what i can do today. ric
Old Nov 18, 2010 | 09:10 AM
HOGRIDA_06's Avatar
HOGRIDA_06
The o-ring inside the female end is a #41 same as the oil drain plugs. I got a 10 pack at lowes for a little over $1.
just plain john
General Topics/Tech Tips
16
Dec 10, 2020 10:28 PM
shackdaddy
Jan 31, 2016 02:52 PM
beemer737
Exhaust System Topics
Aug 25, 2010 05:53 PM
tgarrett1
Jul 8, 2009 08:53 AM
tjr5150
Apr 14, 2009 11:12 AM
