Riding without the battery band - pics
Old Nov 28, 2010 | 03:44 PM
chi45cken's Avatar
chi45cken
Default Riding without the battery band - pics
Guys!
I just removed the battery band on my Bob. I filled the holes with four small bolts (inside) and black nuts (outside).
First - safety question - is it okay to have a metal bolt (flat head) so close to the battery box?
Second - I noticed that there is quite large opening on the battery cover itself (facing toward the tank) - is it safe to leave it open like that?
Third - does it look okay or should I go with chrome nuts?
ALSO - If you have any cool ideas with pix.. other than having it powder-coated - DO share!
Kasia
Old Nov 28, 2010 | 04:07 PM
nkauf21's Avatar
nkauf21
If you really want to leave it off then I would keep the black nuts or some type of black plug. I actually prefer it with the band on. I don't like the indent from where the band is supposed to go. I think if you painted the band with some wrinkle black paint it would flow better.
Old Nov 28, 2010 | 04:25 PM
bobgv's Avatar
bobgv
The air cleaner looks great it matches my timer cover and why dont you powder coat the battery band black oh sorry didnt see the also
Old Nov 28, 2010 | 04:31 PM
Brewtality's Avatar
Brewtality
i did the same, but then i bolted on a small fork bag i found online, check my garage for pics. it looks good, and is small and out of the way but will hold a pair of sunglasses, key fob, pocket knife, a few other small things.
Old Nov 28, 2010 | 04:41 PM
HDDyna2006's Avatar
HDDyna2006
look empty without the band, paint band black, don't have to be pc, epoxypaint runs about 5 bucks.
Old Nov 28, 2010 | 04:46 PM
Swede405's Avatar
Swede405
I painted mine gloss black except for the raised portion which was left aluminum. I might go back and shoot that with a color later but the contrast looks good (might match your air cleaner). With the flat black, why not go with a leather strap, ammo belt, or something similar?
My only safety concern would be rain if the hole is that big but I haven't looked on mine.
Old Nov 28, 2010 | 05:18 PM
filthpig's Avatar
filthpig
I see no problem with anything you have done. I have seen guys use the little plastic hole covers for the rear fender seat bolt. I did not much like the big band on the battery, although I have not done anything about the holes. I have a screaming eagle version to replace it with, when I finally get everything ready to paint.
I see you have got your muffler all mounted up, looks good!
I had read somewhere that you were intrested in blacking out your front end? Are you intrested in some lowers and triple trees you could have powdered?
thanks,
paul
Old Nov 28, 2010 | 05:35 PM
markeejay's Avatar
markeejay
i took the easy option and sprayed it satin black - cheep quick and looks darned good
Old Nov 28, 2010 | 07:23 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by chi45cken
Guys!
Kasia
Maybe paint the band gloss black to match your tank / fenders, that would also give the battery cover some contrast. And to go along with your air filter cover, sand the paint off the top of the ribs like I did on my V Max side covers below. Third photo below, louvers and gloss black.
Old Nov 28, 2010 | 07:35 PM
NoLongerAmember's Avatar
NoLongerAmember
2nd on the Wrinkle Black Paint or Wrinkle PC.
CB
