Help with fork assembly
Old Dec 6, 2010 | 09:02 PM
Trawfish's Avatar
Trawfish
Default Help with fork assembly
I tore down my 09' Street Bob and got some powder coating done. I chose not to change anything but the oil in the forks at this time but I am confused about something.
http://partsfinder.onlinemicrofiche....=13&A=565&B=30
The diagram in the link listed above is the same as the one in my service manuel. My forks do not match the diagram. I do not seem to have #17 (collar spring) and I DO have a long spacer between #16 (the washer on top of the spring) and #31 (the cap bolt) The spacer is just a thin wall piece of steel pipe approx 11' long.
I can not find any diagram that reflects the parts my forks contain. I am about to re-assemble the forks and want to know if this is correct or what? I bought the bike new and the forks have never been touched prior to this.
Any ideas??
Old Dec 6, 2010 | 09:16 PM
teqsand's Avatar
teqsand
Big Kahuna HDF Member
I just did my 08 WG this weekend...#17 does go between #16 and #31....
Old Dec 6, 2010 | 09:51 PM
SURFOR Chop's Avatar
SURFOR Chop
The way the diagram is drawn, it shows the spacer going in before the "spring, rebound" or 'top-out spring' ... that is incorrect ... I am of the opinion that the correct assembly sequence is the spacer goes in last before the top bolt ....
I replaced my stock springs with Race Tech springs and the spacer goes on top in the reassembly instructions ....
Old Dec 6, 2010 | 10:56 PM
Trawfish's Avatar
Trawfish
Ok then, you agree with what I am seeing upon disassembly so they will go back to tegether that way. I have a little more confidence now!!
Thanks for replying
Old Dec 7, 2010 | 02:33 AM
Trawfish's Avatar
Trawfish
All put back together and seem to be working fine... Thanks fellas!
K33b
Feb 13, 2024 04:30 PM
holytown
Oct 19, 2018 05:19 PM
LA_Dog
Dec 20, 2015 07:27 PM
jefla
Mar 31, 2014 08:01 PM
SURFOR Chop
Mar 15, 2011 08:20 AM
