V&H help
Old Dec 11, 2010 | 11:03 AM
bobgv's Avatar
bobgv
[quote=bobgv;7642225]The 1.75s sound much better than stock its a great slip on and you can change the baffle size. You can check the sound on their web site. I have no problem with the sound but imo I should of went with 2.0 baffles they sound a little deeper not as bratty as the 1.75s.
Old Dec 11, 2010 | 11:06 AM
bobgv's Avatar
bobgv
Sorry tried to edit my second post and I need fn glasses
fchava's Avatar
fchava
Originally Posted by Yasky1997
Most post on the Short Shots causing a loss of power are because there is not enough back pressure with the stock baffles. The quiet baffles actually help increase the back pressure. Now cutting the baffles in half would reduce back pressure more like drag pipes. Which are good if you run your bike at WOT. If you have a stock or stage 1 set up on your bike I doubt you are losing 10-15 hp on pipes alone. I went from stock pipes to cycle shack slip on and the SOTP felt improved. then I switched to the V&H SS w/quiet baffles and it was about the same as the slip ons.
its just stage 1 with TW-555's
laabdog
Apr 28, 2017 09:29 AM
stinkerbill
Feb 26, 2016 01:05 PM
Red Bull
Aug 31, 2010 03:43 PM
TJRKC
Exhaust System Topics
Mar 19, 2008 06:53 PM
AdrianVall
Nov 7, 2007 08:11 AM
