handlebar change
Old Dec 20, 2010 | 07:35 PM
ahorsewithnoname's Avatar
ahorsewithnoname
Default handlebar change
Bought a Flanders 8" handlebar thinking to lower the stock 10 inch.
Dilemma for me is that the Flanders is chromed steel and the Stock Harley is stainless steel.
My 2010 Bob is the smoothest Dyna I've ever owned. The way I'm thinking is that Harley did a lot of work on tuning the motor balance, getting a smooth combustion burn with the head chamber design and valve timing that what little vibration is felt in the handlers might be damped by the bar design, ie stainless steel and thickness, bend, width shape. I'd hate to upset the bar vibration damping with the Flanders bar with different characteristics.
Anyone out there ever notice any difference in vibration on the grips after changing bars?
By they way, RICOR advertises a new grip design with active vibration control.
Greatgrandpop
Old Dec 20, 2010 | 08:42 PM
nevil's Avatar
nevil
After 3 sets of completely different bars and grips I can't say that any of those combos had a noticeable difference in vibration. In fact, I have no problems at all with vibration anywhere on the bike. Haven't seen those Ricor grips but it would be overkill for me.
What might make more of a difference would be using the poly bushings.
Old Dec 20, 2010 | 09:36 PM
bigdaddy33's Avatar
bigdaddy33
Haven't noticed or even thought about a possible difference in vibrations resulting from changing the handlebars. I think a much bigger concern would be how it affects your comfort and the handling characteristics.
Greatgrandpop
Old Dec 20, 2010 | 10:29 PM
archergodwin's Avatar
archergodwin
I think you are surmising that when the engine designers were thinking about timing and head parametrics... they had handlebar vibration in mind as well. I would bet dollars to donuts they did not... hence they mount the bars with vibration dampning donuts, because they did not want to spend the dollars to reduce it 'that' much.
.. you're not going to affect it much with whatever you do.... unless you install 18" apes and poly bushings... then you will get some added buzzing I bet
Tozco
2018+ Softail Models
63
May 22, 2025 07:02 AM
Paul-Pacman
Apr 29, 2016 12:45 PM
GPHDXLC
Mar 19, 2008 10:33 AM
ronyd
Oct 9, 2007 08:42 AM
hd_sob
Jul 30, 2006 02:16 PM
