guys running lowered bikes on 18" rear rims please come in....
Old Jan 10, 2011 | 02:26 PM
toastman's Avatar
toastman
Default guys running lowered bikes on 18" rear rims please come in....
am i gonna have any issue going 18" in the rear and lowering my bike down?
i do about 90% solo riding, and yes i understand i'll have less suspension travel with my new 11" progressives.
i don't want to shred the **** out of my wiring on the first bump i hit at speed...is this a major concern or should i be ok?
was also looking into buying the wiring channels that relocate the rear wiring to the sides of the fender to give myself a little peace of mind.
thanks
Old Jan 10, 2011 | 02:34 PM
animalnoll's Avatar
animalnoll
I have had no issues with the Progressive 11" 412s on the rear and a set of PM 18" Rival wheels.....GO FOR IT!!!
Old Jan 10, 2011 | 03:20 PM
Robbie13's Avatar
Robbie13
LOSER
Just an idea, when I cut my fender and struts, I re-routed the wiring between the the inside of the strut and the outside of the fender along the inside of the shallow slot of the strut. My wires don't (of course yours is different) don't go nowhere near the tire in the fender.
Old Jan 10, 2011 | 03:28 PM
toastman's Avatar
toastman
that's not a bad idea at all, but i stil need to get wires to my brake light (you dont have one dead center on your fender)
i think the channels (or guides or wtf ever they're called) that HD sells will do the trick
Old Jan 10, 2011 | 06:37 PM
nkauf21's Avatar
nkauf21
I don't have any issues with my set-up.
Old Jan 10, 2011 | 06:53 PM
Dingobob's Avatar
Dingobob
I've got 11" progressive and 18 x 200. No chance of hitting wires.
Old Jan 10, 2011 | 07:28 PM
parts eeter's Avatar
parts eeter
When I had sigs on my struts I removed the inner strut bracket and hammered the OEM bulge flat and used ductape to hold my wires down snug about 3 inches past the rear of the bracket. then I removed sigs alltogether with a HD docking hardware kit. Now I have tons of clearance. My bike is only lowered when my 265lb **** is installed upon seat!
You will have to either use the brackets that feed wires out the rear, (08 and newer SB)hammer the older style brackets bulge flat like I said, or relocate sigs. Plenty of options.
Old Jan 10, 2011 | 07:59 PM
reded's Avatar
reded
Exact same setup, no problems in 10,000 miles. I ride solo most of the time as well but I like the smaller ladies, heaviest one I've had on it was maybe 125lbs, still no problems even 2 up.
Old Jan 10, 2011 | 08:23 PM
toastman's Avatar
toastman
thanks for the input guys!
yeah reded, i live by the "no fat chicks" rule as well.
FBFletch
Dec 23, 2020 02:17 PM
JHC210
2014-2024 Touring Models
May 22, 2018 10:58 AM
antman27
May 4, 2015 08:47 PM
Sal C
Oct 13, 2012 09:46 AM
junglejoe
Aug 27, 2012 03:48 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
