Retainning clip position?
Old Jan 28, 2011 | 01:50 PM
ed gien's Avatar
ed gien
Default Retainning clip position?
Why does the position of a retainning clip matter when you installed a new clutch cable? I already installed but read this after I did it. Is there a way to test it? Its going to snow for 2 more months so a test ride is out of question.
Old Jan 28, 2011 | 01:53 PM
blink1968's Avatar
blink1968
i always do it like it is instructed....they do it like that for a reason
Old Jan 28, 2011 | 01:56 PM
Faast Ed's Avatar
Faast Ed
Do it right, or keep your hands off it.
I don't recall the reason for the position of that clip, but there is one.
You likely will be fine, but why find out in the middle of a trip, far from home?
Plenty of time to fix it properly!
Old Jan 28, 2011 | 02:41 PM
kk6pg's Avatar
kk6pg
The retaining ring opening must be centered above the break in the ribbing at the bottom of the release cover.
This will make sure both ears of the snap ring have adequate support, and the unsupported meat of the ring is part hanging out in free space. The last thing you want is for the ring to pop loose from side loading because the meat wasnt where it was supposed to be. If you spin your snap ring counter clockwise 45°, you'll be in business
Old Jan 28, 2011 | 04:08 PM
ed gien's Avatar
ed gien
That's really true about leaving the part of ear out of the air part.that is probally why they want it at that point in pic? I'm good then.
Old Jan 28, 2011 | 04:44 PM
bberck's Avatar
bberck
Instal it the way it shows if you do it backwards it can come undone. Dont ask me how I know lol
Old Jan 28, 2011 | 04:51 PM
Faast Ed's Avatar
Faast Ed
El-delete-o
Old Jan 28, 2011 | 05:54 PM
misfitJason's Avatar
misfitJason
just make sure it is seated in the channel. But no the direction of it does not matter at all.
Old Jan 28, 2011 | 11:51 PM
==ShaDoW=='s Avatar
==ShaDoW==
Never even knew you had to have it in a certain postion, I figure if my clutch was correct before the change it should be ok after the change I just clipped it into the arm that sticks out and left it at that, I adjusted play on the cable after I put it back together, my clutch is working fine,
YodaddyKeith
Oct 23, 2019 02:55 PM
TwoBlue02
Feb 10, 2017 01:45 AM
roadkinglobo
Jul 9, 2009 04:03 PM
03 Softail
Sep 12, 2007 07:19 PM
