Remove Front Wheel Without Removing Caliper?
Old Jan 29, 2011 | 06:13 AM
OU812's Avatar
OU812
There are 2 ways to loosen those bolts, one is to heat them up with a small torch , it will melt the locktight and come loose. The second way is to put more red locktight on the old to soften it up & the bolt will break loose. Good Luck
Old Jan 29, 2011 | 08:52 AM
JRK5892's Avatar
JRK5892
ok to remove those bolts... you have 2 things... first always when pulling stuff off that is lock tited... use a punch inthe center of the bolt and give it a smack! this will help to break it loose and they will come right out... if that does not work use a heat gun to heat up the bolt to melt the lock tite and it will spin right out as well... both ways work bud
Old Jan 29, 2011 | 11:06 AM
Whiffleboy's Avatar
Whiffleboy
It's been a while since I've posted here (bike's been running great), but, this is exactly why I love this place. Thanks for all the tips. :-)
Old Jan 29, 2011 | 11:19 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
And, if you ever get the caliper bolts off, use anti seize on them...
Old Jan 29, 2011 | 05:07 PM
NoLongerAmember's Avatar
NoLongerAmember
Torch on the caliper? Maybe if you have a micro torch and if can keep the flame off the fork and caliper to keep from burning off the paint and I don't see how red loctite is going to wick up to the threads and melt the old loctite, not to mention we don't know if they did use loctite.
I would not recommend anti-seize on the caliper bolts, clean, dry and torqued to spec is sufficient. 28-38 ft lbs.
I would highly recommend you remove and replace these fasteners since you have no way of knowing if you have stressed them or reduced the clamping force trying to remove them.
In retrospect, if you experience a bolt that will not come loose stop and think about how to keep from damaging the the bolt. Like Joe mentions, center punch in the middle of the fastener or an impact driver alone or in conjunction with the center punch method. Impact drivers are inexpensive and can break a fasteners loose quickly.
CB
Old Jan 29, 2011 | 06:04 PM
Whiffleboy's Avatar
Whiffleboy
OK...I'm about to lose my **** right about now. After a couple of trips to Home Depot/Sears and $$ later, I managed to get the caliper bolts off after using an impact and a stronger box wrench (thanks for the tip). I even bought a Bolt Out just in case.
Got all set to remove the axle only to find the #$%&!@ shop that jacked up the caliper bolts also jacked the slider cap screws (guess I should've seen that one coming). They're completely stripped on the inside. Can't continue with the process now.
Done with it for now. I'll figure out how to deal with those bolts after Superbowl.
You know...the tires were the only thing I've taken the bike to a shop for (aside for one small injector wire short). And look what happens!!!
DIY!!!!
So pissed right now. :-(
Old Jan 29, 2011 | 08:48 PM
DCLXVI's Avatar
DCLXVI
Well I have to tell you that those 2 little allen head bolts on the right fork cap are made from some pretty soft metal. Mine didn't strip but you could feel them about to. I replaced mine with some good quality allen bolts that where 6mm instead of 5mm. The bolt size if I remember was 8mm x 1.25mm. Length was 30 or 35 mm. I foung mine at Lowe's.
Old Jan 30, 2011 | 08:17 AM
OU812's Avatar
OU812
CB
Heat bolt to 260c as per Locktite.com or new locktite on old will melt it,try it it works.
Old Jan 30, 2011 | 06:36 PM
NoLongerAmember
DIY!!!!
I also had trouble with the the lower cap button head screws. They are SS and strip very easily, of course over tightening them does not help. I replaced them with the OE and they still want to strip even when being careful. A switch to steel, even to the same button head style, is a better option for sure.
500* and you do that how with out damage of the surrounding area or possibly the piston seals??? I don't need to try it because I don't use red loctite where it is not warranted. The OP did not say he found Red on the caliper bolts, so who knows if that was the case anyway???
CB
Old Jan 30, 2011 | 07:58 PM
OU812's Avatar
OU812
CB
I stand by what I said, you can pick it apart and find fault in everything. It sounds like that is what you are good at. You can heat up locktite , whether it is red,green or blue. If heating it up is not possible you can put fresh locktite on old locktite and it will soften it. It does not matter if you use locktite or not, I'm just putting some facts out there that OP can use. just because you have never done it doesn't mean it doesn't work, so I'm sure you need the last word so flame on.
