Remove Front Wheel Without Removing Caliper?
Old Jan 28, 2011 | 04:00 PM
Whiffleboy's Avatar
Whiffleboy
Default Remove Front Wheel Without Removing Caliper?
Hi all. I was going to finish up my 20K by changing out the fork oil on my 06 Street Bob. I went to take the caliper off and found that both caliper bolts were either over-torqued or locktited to the point they both stripped. I had a tire change about 2500 miles ago and I'm assuming that's when the bolts were reinstalled incorrectly. Anyway...
I'm wondering if you guys know whether the tire/wheel can clear the caliper if I try to take the wheel off and put it back on without removing the caliper. It looks next to impossible, but, I figure someone's tried before and maybe they know.
Thanks in advance.
(Now to figure out the caliper bolt problem).
Old Jan 28, 2011 | 04:04 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you use a 12pt socket? a 6 point 10mm will just spin and spin.
JRK5892's Avatar
JRK5892
nope needs to be pulled to clear the rim
Old Jan 28, 2011 | 04:06 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
I never remove my caliper when I remove my rim/tire...should just slide right out..
Old Jan 28, 2011 | 04:07 PM
Whiffleboy's Avatar
Whiffleboy
Yeah, I did. They definitely screwed it up for me. Wondering...
I have a Mighty Vac. Think I can suck the fluid out from the top?
Old Jan 28, 2011 | 04:08 PM
Whiffleboy's Avatar
Whiffleboy
Did you deflate your tire or could you do it fully pressured?
**EDIT**
I see from your pic that your wheel could sort of allow that. I'm fully spoked here.
Old Jan 28, 2011 | 04:12 PM
AR-15 DEUCE
I was thinking now...my tire is a 90/90/21....maybe skinner than yours..
Old Jan 28, 2011 | 04:15 PM
bberck's Avatar
bberck
I dont remove my front caliper when I take off my front wheel off. I did the first time because the manual said to but after I did I didnt see any reason to so I never have again.
Old Jan 28, 2011 | 04:17 PM
Whiffleboy's Avatar
Whiffleboy
Do you have a stock wheel?
Old Jan 28, 2011 | 04:20 PM
bberck's Avatar
bberck
I had the stock mag and now have the HD chrome version of the same wheel, both go on and off no problem.
