engine light on
Old Feb 3, 2011 | 05:11 AM
rev777's Avatar
rev777
1st Gear
Default engine light on
Hi there
I have a 2000 FXDX that we have just fitted an S&S T111 engine in (carburettored).
http://www.sscycle.com/product/cart....detail&p=21059
Today I started it up for the first time.
However the engine light is doing strange things.
(The light is the word ENGINE in red in the tacho.)
Sometimes it goes off and then after a while it comes back on.
Sometimes (one time?) it will even go back off again.
I have only started the engine about 5 times but I am not game to let it run too long with the engine light on.
The ECM is the S&S IST unit that comes with the engine.
Thanks
Neil
Old Feb 3, 2011 | 05:32 AM
Iceman24's Avatar
Iceman24
It's flasing a trouble code - gotta read the sequence to see which one...
Old Feb 3, 2011 | 03:59 PM
rev777's Avatar
rev777
1st Gear
OK this is what happens
- Turn on ignition
- ENGINE lights in red
- ENGINE light goes out
- ENGINE light comes on again and then goes off
If I start the bike it will run for about half a minute and then it seems to lose power and the ENGINE light comes on again.
I tried the diagnostic trouble codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button.
The odometer shows d01CLr (presumably meaning diagnostic #1 clear)
press odometer reset button - now shows d02SEt (does that mean that diagnostic #2 is set?)
pressing the odometer reset button then displays d03CLr, d04CLr, d05CLr, d06CLr, d07CLr, d08CLr, d09CLr
the next press after that displays CAL 10 (whatever that means)
pressing it again starts the sequence again
This is a 2000 FXDX
myrtle2008
Jan 16, 2013 08:01 PM
georgemt54
Oil Archive (no new posts)
Sep 13, 2012 08:15 PM
Classic Rider
Mar 3, 2012 08:30 PM
rev777
Feb 8, 2011 06:49 AM
zaraghjr
Aug 2, 2010 11:58 PM
