My 09 street bob has a flat
Old Feb 7, 2011 | 05:31 PM
zoomstbob's Avatar
zoomstbob
5th Gear
Default My 09 street bob has a flat
Is there a tube in the rear tire? Can a puncture be repaired? Looks like a nail in it.
Old Feb 7, 2011 | 05:45 PM
bigmikaele's Avatar
bigmikaele
Not sure if you bought it new or used so don't mind the next question. Does it have spoked wheels? If so yes it is tubed... might be able to repair it but it is safer to replace. You only have one rear tire and the piece of mind is so much more valuable then a patched repair. JMO
Old Feb 7, 2011 | 06:53 PM
n2gzus's Avatar
n2gzus
I have an '09 bob...had a nail in the rear tire this past summer. I took the tire off and took it to my local indy where they replaced the tube for me. I kept the same tire (which is still mounted) and have had no problems with it. If you have good tread left I'd say just buy a tube and replace the punctured one.
Edit: Bigmikaele, I misread your post...I was thinking you said replace the tire.
Anyway, ditto to what you said.
Old Feb 7, 2011 | 07:10 PM
reded's Avatar
reded
Have the tire patched at the hole and put a new tube in it. Good as new.
Old Feb 7, 2011 | 07:21 PM
Aaron 09FXDB's Avatar
Aaron 09FXDB
I have a 09 FXDB as well. Yes, tube. Yes can be replaced. As for repairing the tire, like many of said it's possible to repair...but I'd look at where the nail was how close to the side, size of the puncture. But I'd also look to replace the tire probably. IMHO.
Old Feb 7, 2011 | 07:41 PM
stilup's Avatar
stilup
Small hole in the middle and not near the side is OK with a good patch.
If it works on big trucks then it should work no problem on a bike tire.
Even with a new tube the tire needs a good patch, one that covers a good area.
I wonder if that tire is covered . Did you purchase raod hazzrd insurance when you bought it?
JG09
Jun 21, 2011 04:05 PM
Rustybeater91
Wheels/Tires
May 17, 2011 06:51 PM
cjm8806
Mar 26, 2010 04:38 AM
desertglide
May 19, 2009 03:46 AM
bnsoftailrider
Sep 2, 2006 06:26 PM
